I am looking for a pressure sensor to use with an ESP 32
Something along the lines of this device. Does anybody have any recommendations of a device similar to this so they have experience with
I am trying to monitor the Low pressure side of a regulator on a nitrogen bottle. From 0-15 psi
From what I can see this particular device outputs a voltage of up to 90 V.
I have a 1/4” hose on the outlet of the regulator so it would need to have a barb type fitting.
This TR Series device you linked does not output up to 90V. According to the datasheet, it outputs 10-90% of the supplied voltage (%Vs) - so if you supply it with 5V, the output will vary from 0.5 to 4.5V.
I have one of these measuring irrigation water pressure. Seems very accurate but mine did get clogged from dirty water supply. Goes into ADS1115 which measures up to something like c.6v
