This is my light automation, that got quite complex over the time. But now, it fits all my needs (all my current needs…).
I use it for >50 lights at the moment - some are on/off lights, most are dimmable and some are RGB color lights.
Be warned: It uses a lot of helper entities for brightness, blocking and so on. By that, it gets very flexible. I use a package for each light, so by “search and replace” I can easily copy the config of one light as a starting point for another one.
Description of the inputs and helper will follow in the next post, due to character limitaiton
blueprint:
name: Automation for Dim and Switch Lights
description: Pretty complex automation with a lot of helper entities
domain: automation
input:
light_entity:
description: The light that shall be controlled.
selector:
entity:
domain: light
automation_switch:
description: Switching the automation function on or off without deactivating the HA automation
selector:
entity:
domain: input_boolean
description: Binary Sensor that represents occupancy
selector:
entity:
domain: binary_sensor
helper_effective_brightness:
name: Helper Effective Brightness
description: Helper Entity (sensor), that keeps the current effective brightness
selector:
entity:
domain: sensor
helper_basic_brightness:
name: Helper Basic Brightness
description: Helper Entity (sensor), that keeps the current basic brightness
selector:
entity:
domain: sensor
helper_is_too_dark:
name: Helper showing if too dark
description: Helper Entity (binary sensor), that indicates if it is too dark
selector:
entity:
helper_is_too_bright:
name: Helper showing if too bright
description: Helper Entity (binary sensor), that indicates if it is too bright
selector:
entity:
helper_auto_switched:
name: Helper Auto-Switched
description: Variable that stores information if light was switched by automation
selector:
entity:
helper_manually_switched_on:
name: Helper Manually Switched On
description: Variable that stores information if light was switched on manually
selector:
entity:
helper_manually_switched_off:
name: Helper Manually Switched Off
description: Variable that stores information if light was switched off manually
selector:
entity:
helper_switching_off_entities:
name: Helper Switching Off Entities
description: Sensor for number of active switching off entities
selector:
entity:
domain: sensor
helper_keeping_on_entities:
name: Helper Keeping On Entities
description: Binary Sensor that indicates if a keeping on entity is active
selector:
entity:
helper_keeping_off_entities:
name: Helper Keeping Off Entities
description: Binary Sensor that indicates if a keeping off entity is active
selector:
entity:
helper_keeping_fix_entities:
name: Helper Keeping Fix Entities
description: Binary Sensor that indicates if a keeping fix entity is active
selector:
entity:
mode: queued
max: 20
max_exceeded: silent
variables:
helper_effective_brightness: !input helper_effective_brightness
helper_basic_brightness: !input helper_basic_brightness
light_entity: !input light_entity
- platform: state
entity_id: !input automation_switch
to: 'on'
- platform: homeassistant
event: start
- platform: state
entity_id: !input trigger
to: "on"
- platform: state
to: "off"
- platform: state
entity_id: !input helper_switching_off_entities
- platform: state
entity_id: !input helper_is_too_dark
to: "on"
- platform: state
entity_id: !input helper_is_too_bright
to: "on"
- platform: state
entity_id: !input light_entity
to: ~
- platform: state
entity_id: !input helper_keeping_on_entities
to: "off"
- platform: state
entity_id: !input helper_keeping_off_entities
to: "off"
- platform: state
entity_id: !input helper_keeping_fix_entities
attribute: brightness
to: ~
- platform: state
entity_id: !input helper_effective_brightness
attribute: special_brightness
to: ~
- choose:
# path 1
- conditions:
- condition: or
conditions:
- condition: trigger
sequence:
- service: input_boolean.turn_off
entity_id: !input helper_auto_switched
- choose:
- conditions:
sequence:
- wait_template: "{{ states(light_entity) in ['on','off'] }}"
default: []
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- condition: state
state: 'on'
- condition: state
state: 'off'
- condition: state
state: 'off'
entity_id: !input helper_manually_switched_off
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
default: []
- choose:
- conditions:
- condition: template
value_template: '{{ state_attr(helper_effective_brightness, "color") == none }}'
sequence:
- service: light.turn_on
data_template:
brightness_pct: >
{{ states(helper_effective_brightness) | int(75) }}
- conditions:
value_template: '{{ state_attr(helper_effective_brightness, "color") != none }}'
sequence:
data_template:
brightness_pct: >
rgb_color: >
{{ state_attr(helper_effective_brightness, "color") }}
default: []
# path 2
- conditions:
- condition: state
state: 'on'
sequence:
- condition: state
state: 'on'
- condition: state
state: 'off'
- condition: state
state: 'off'
entity_id: !input helper_manually_switched_on
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
default: []
- service: light.turn_off
default: []
- conditions:
- condition: state
state: 'off'
sequence:
- condition: state
state: 'on'
- condition: state
state: 'off'
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
default: []
default: []
# path 4
- conditions:
- condition: state
state: 'on'
sequence:
- condition: state
state: 'on'
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
default: []
- choose:
- conditions:
sequence:
data_template:
brightness_pct: >
- conditions:
sequence:
data_template:
brightness_pct: >
rgb_color: >
default: []
default: []
# path 5
- conditions:
sequence:
- condition: state
state: 'on'
- condition: state
state: 'off'
- condition: state
state: 'off'
- condition: state
state: 'on'
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
default: []
- choose:
- conditions:
sequence:
data_template:
brightness_pct: >
- conditions:
sequence:
data_template:
brightness_pct: >
rgb_color: >
default: []
# path 6
- conditions:
sequence:
- condition: state
state: 'on'
- condition: state
state: 'off'
- condition: state
state: 'off'
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
default: []
# path 7
- conditions:
sequence:
value_template: '{{ is_number(trigger.to_state.state) }}'
value_template: '{{ is_number(trigger.from_state.state) }}'
value_template: '{{ (trigger.to_state.state | float(0)) > (trigger.from_state.state | float(1)) }}'
- condition: state
state: 'on'
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
default: []
# path 8
- conditions:
sequence:
- condition: state
state: 'on'
- condition: state
state: 'on'
- condition: state
state: 'off'
- condition: state
state: 'off'
- condition: state
state: 'off'
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
default: []
- choose:
- conditions:
sequence:
data_template:
brightness_pct: >
- conditions:
sequence:
data_template:
brightness_pct: >
rgb_color: >
default: []
# path 9
- conditions:
sequence:
- condition: state
state: 'on'
- condition: state
state: 'off'
- condition: state
state: 'off'
- condition: state
state: 'off'
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
default: []
# path 10
- conditions:
value_template: >
{{ trigger.from_state.state != 'unavailable' }}
value_template: >
{{ trigger.from_state.state != 'unknown' }}
value_template: >
{{ trigger.from_state.state != 'none' }}
sequence:
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
- choose:
- conditions:
value_template: >
{{ trigger.to_state.state == 'on' }}
value_template: >
{{ trigger.from_state.state == 'off' }}
sequence:
# path 11
- conditions:
value_template: >
{{ trigger.to_state.state == 'off' }}
value_template: >
{{ trigger.from_state.state == 'on' }}
sequence:
default: []
# path 12
- conditions:
- condition: state
state: 'on'
sequence:
default: []
# path 13
- conditions:
sequence:
- condition: state
state: 'on'
- condition: state
state: 'on'
- condition: state
state: 'on'
- condition: state
state: 'off'
- condition: state
state: 'off'
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
default: []
- choose:
- conditions:
sequence:
data_template:
brightness_pct: >
- conditions:
sequence:
data_template:
brightness_pct: >
rgb_color: >
default: []
# path 14
- conditions:
sequence:
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- condition: state
state: 'on'
- condition: state
state: 'off'
- condition: state
state: 'off'
- condition: state
state: 'off'
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
default: []
# path 15
- conditions:
- condition: state
state: 'off'
sequence:
- condition: state
state: 'on'
- condition: state
state: 'off'
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
default: []
# path 16
- conditions:
- condition: state
state: 'on'
sequence:
- choose:
- conditions:
value_template: >
{{ (trigger.to_state.attributes.brightness | int(0)) > 0 }}
sequence:
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
default: []
- choose:
- conditions:
sequence:
data_template:
brightness_pct: >
{{ trigger.to_state.attributes.brightness | int(75) }}
- conditions:
sequence:
data_template:
brightness_pct: >
rgb_color: >
{{ trigger.to_state.attributes.color }}
default: []
# path 17
- conditions:
value_template: >
{{ (trigger.to_state.attributes.brightness | int(0)) == 0 }}
sequence:
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- condition: state
state: 'off'
- condition: state
state: 'off'
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
default: []
- choose:
- conditions:
sequence:
data_template:
brightness_pct: >
- conditions:
sequence:
data_template:
brightness_pct: >
rgb_color: >
default: []
# path 18
- conditions:
- condition: state
state: 'off'
sequence:
- condition: state
state: 'off'
- condition: state
state: 'off'
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
default: []
default: []
# path 19
- conditions:
- condition: state
state: 'off'
sequence:
- condition: state
state: 'off'
- condition: state
state: 'off'
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
default: []
default: []
default: []
# path 20
- conditions:
sequence:
- condition: state
state: 'on'
- condition: state
state: 'off'
- condition: state
state: 'on'
- delay: 1
- choose:
- conditions:
sequence:
data_template:
brightness_pct: >
- conditions:
sequence:
data_template:
brightness_pct: >
rgb_color: >
default: []
default: []
