I have an automation ‘A’ that monitors the state of a binary sensor and runs scripts when it is either turned off or on. This works perfectly.
However, I now have a situation where I would like to have another automation ‘B’ change the state of the sensor but not trigger the automation ‘A’.
I have tested disabling ‘A’ as the first action when ‘B’ runs and then re-enabling it at the end. This works but feels clunky - is there a more elegant method? Thanks
Substitute in the entity ID for B, and change 5 to whatever value suits.
Alternative is to create a Toggle helper (input_boolean) and get B to turn that on. Then set up an if/then or choose in A’s action to test the value of that toggle helper and run the normal action if it’s off, or turn it off if it’s on.
@koying thanks - I didn’t know about trigger context. It looks useful but in this case I have several automations that change the boolean only one of which I don’t want to have it trigger on the change.
@petro thanks for the suggestion but I’m not sure I understand why you are recommending checking the context in this situation.
I have a input boolean which is monitored for changes (on or off) by automation ‘A’
I have more than 1 automation that change the input boolean and in these cases I do want A to trigger.
I have one new automation ‘B’ that changes the input boolean but in this case I don’t want it to trigger A.
As I understood it checking the context will in this situation always tell me that it was an automation that altered the input boolean, there would be no way to tell if it was B or not.
Please let me know if I have misunderstood - thanks
@petro Ah OK I did misunderstand, so context sounds like the way to go.
Having added the template you kindly provided to my test automation it seems to be working but the ‘other way around’ i.e.:
If I set != in the template then A runs when the boolean is toggled by B
If I set == in the template then A does not run when the boolean is toggled by B
I could just leave it like that as it appears to be working but I’d really appreciate it if you could explain why or if I’ve missed something (again)
alias: Automation A
description: ""
triggers:
- alias: Changes to ON
entity_id:
- input_boolean.pets
to: "on"
trigger: state
- alias: Changes to OFF
entity_id:
to: "off"
trigger: state
conditions:
- condition: template
value_template: >-
{{ trigger.to_state.context.parent_id !=
states.automation.automation_b.context.id }}
actions:
- alias: logbook ON
if:
- condition: trigger
id:
- "on"
then:
- action: logbook.log
metadata: {}
message: ON ON
- alias: Logbook OFF
if:
id:
- "OFF"
then:
metadata: {}
message: off off
mode: single
