Hi there,
I am using an ESP8266 on my gas meter. Unfortunately, the wifi is rather bad so the ESP often loses connection. My ESPHome code looks like this:
globals:
- id: gas_total_pulses
type: int
restore_value: true
initial_value: '525984' # hier kann der Gaszählerstand initialisiert werden
binary_sensor:
- platform: gpio
pin:
number: GPIO5
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
on_press:
then:
- lambda: id(gas_total_pulses) += 1;
device_class: gas
unit_of_measurement: "m³"
state_class: "total_increasing"
icon: "mdi:fire"
update_interval: 5s
accuracy_decimals: 2
lambda: |-
return id(gas_total_pulses) * 0.01;
The problem I am having is that if the current pulse output is high on connection re-establishing it is considered as new pulse even though the gas meter is not moving at all, see the example image:
In this example the counts only come from the connection re-establishing and are wrong.
How can I prevent this to happen? E.g. only increment if the previous state was low or something like this?
Thanks and best regards
Sven
