I have a garage door that’s controlled by an MQTT cover. I also set up a notification to ping me when the door is open based on the door sensor (not actuation of the door control relay). Is there a way to limit the notification to only occur when the door sensor reads open but it was NOT initiated from within Home Assistant?
How do you trigger the opening of the door?
You could add a condition in the notification based on the “trigger” element (switch off for 5 minutes for example)
My go-to for these things is here.
Add an input_boolean to the mix, that you turn on when you use an automation to open the door, and then off any time the door closes. Then you can use the state of the input_boolean as a condition in the notification.
MQTT Cover:
cover:
- platform: mqtt
friendly_name: Garage Door
state_topic: "homeassistant/garage/door/status"
state_open: "OPEN"
state_closed: "CLOSED"
command_topic: "homeassistant/garage/door/control"
payload_open: "OPEN"
payload_close: "OPEN"
payload_stop: "OPEN"
optimistic: false
retain: false
value_template: '{{ value }}'
I’m going to try this and see if it works:
- alias: Notify iOS Garage
initial_state: true
hide_entity: true
- platform: state
entity_id: cover.garage_door
to: 'open'
condition:
- condition: template
value_template: '{{ as_timestamp(now()) - as_timestamp(states(switch.sensor.garage_door_control.last_updated)) < 10 }}'
- service: notify.ios_dkphone
title: "Garage Alert"
message: "GARAGE IS OPEN"
push:
badge: 0
category: 'GARAGE1'
@sjee any thoughts on this since you look like you have it working with this?
