I report CPU (and GPU temperature via an MQTT broker. The incoming message looks like
CM/polana/temperature/CPU,GPU 1628262001, 51.540, 51.5
I’m extracting the CPU temperature using the following sensor entry in configuration.yaml
- platform: mqtt
state_topic: "CM/polana/temperature/CPU,GPU"
unique_id: "polana_temp"
unit_of_measurement: "°C"
value_template: "{{ value.split(',')[1] }}"
This works as desired except that it converts the temperature to °F. I’m in the US and °F is correct for most of my displays, but for some like CPU temperature I’m accustomed to seeing them in °C. Is there a way to prevent conversion of particular sensors?
Thanks!
