I am trying to start my circulation pumps for lets say 2 minutes once every second week and could not find out on how to do that.
Any suggestions appreciated.
Tried this?
automation 3:
- platform: time_pattern
# You can also match on interval. This will match every 5 minutes
minutes: "/5"
It should support days:
but you can also try hours: 336
Alternatively, i have this that runs weekly:
- id: a5084c0152054338b6aed1e7638e886f
alias: Weekly RESTART at 4 AM Tuesday
- platform: time
at: 04:00:00
condition:
- condition: time
weekday:
- tue
- service: notify.just_me
message: Restarting
- service: hassio.host_reboot
mode: single
Ow, and check this out, it seems identical to your issue:
I think this can be made to run every other week also.
If there is an action to set an input number of current weeknum +1 :
service: input_number.set_value
entity_id: input_number.pump_week_plus_one
value: '{{ now().isocalendar()[1] | int + 1 }}'
And then use a condition in the automation that current weeknum != input_number.pump_week_plus_one
That should mean when it runs, it “blocks” next week from running, but the week after that the condition will be true.
alias: Pump every other week
- platform: time
at: 04:00:00
condition:
- condition: time
weekday:
- tue
- condition: template
value_template: >-
{{ now().isocalendar()[1] | int !=
states('input_number.pump_week_plus_one') | int }}
- service: [ Run Pump service ]
- service: input_number.set_value
mode: single
EDIT:
This will only fail at new year.
You save the input number modulo 52, but that means it will fail on years with 53 weeks.
Not sure if there is a jinja for number of weeks in current year.
EDIT2:
Now that I think about it. Perhaps a better failsafe metod is to use a datetime helper and set it to next week using +timedelta(days=7). That way all the hard work is done for us and we know the condition will work.
Thanks!
You can also use hacs Garbage Collection. It allows most anytime combination
Here is the github repository
He also has another for holidays that adds on to Garbage Collection
It is very handy and I use it alot.
Here is how I reboot every 3 days to keep the system fresh.
garbage_collection:
- name: Boot HACore
frequency: "every-n-days"
first_date: '2021-04-09'
period: 3
alias: Reboot HA Core
description: Reboot home assistant at 11:57:19 PM
- platform: time
at: '23:57:19'
condition:
- condition: state
entity_id: sensor.boot_hacore <-- sensor is 0 on day, 1 before and 2 all other days
state: '0'
- service: homeassistant.restart
mode: single
It is very versatile
