I would like to write an automation that triggers when a numeric state attribute suddenly decreases by greater than “X” units. The automation would need to compare the current value of a state attribute against the previous value of a state attribute. Is this possible?
Unfortunately, the point of reference intermittently changes, and therefore I cannot use a fixed value.
Examples:
- If the media player decreases the attribute ‘volume_level’ by more than 0.2 units (in less than ‘Y’ seconds), mute the media player.
- If the media player increases the attribute ‘volume_level’ by more than 0.2 units (in less than ‘Y’ seconds), unmute the media player.
Additional Examples:
- If a freezer temperature sensor value increases more than 20% from previous steady state value (in 10 minutes), trigger alert automation
- If stock ticker price drops more than 5% (in < 30 minutes), trigger alert automation
The above examples are not the automations that I intend to write, however they exhibit similar logic. If this is possible, I imagine it will use templates
{{ PREVIOUS state_attr("media_player.chromecast", "volume_level") - CURRENT state_attr("media_player.chromecast", "volume_level") > 0.2 }}
If this is not possible I wonder if I could use the derivative helper to trigger an automation based on the rate of change in numeric values.
