Hi Guys,
I have some zigbee curtain motors set up in HA that I control from Hubtat using zigbee2MQTT. This has been working fine for a long time. The curtain motors then suddenly stopped working seemingly for no apparent reason. Only two things has happened that I am aware of where one was a power outage and the second is that I installed ZHA.
Forgive me if I ask not so brilliant questions, but can zigbee2mqtt and ZHA coexist or are the mutually excluding?
If I select START ADD ON and try to start zigbee2mqtt it will not start. The error message ‘502: Bad Gateway’.appears in the top left corner.
I wanted to find any log files and used the terminal but could not find any.
Any suggestions on how to persue the reason zigbee2mqtt will not start?
Cheers,
