Hi All,
I am using a splitted configuration in combination with packages.
Now there is a custom integration which works fine if I directly put its configuration within configuration.yaml or in a splitted configuration file.
But if I put it within a package I receive an configuration error.
Using python3 -m homeassistant --script check_config --config "/config" -i
I can print out the complete/resolved configuration.yaml. But only when the configuration is valid.
If it is not valid I do not receive any printout of what was resolved…
Is there any way to see which yaml layout the configuration is resolved to on a vailed verification?
