Priority parameter for Notify My Android messages
The current code sends all NMA notifications with a priority of 0. I would like to be able to set the priority so I have replaced this line in my nma.py:
'priority': 0,
with
'priority': kwargs.get('data').get('priority', '0'),
Thus I can send a message with priority like this:
  message: x
  title: y
    priority: 2
Since data seems to always be included the code should not throw errors, but I’m not sure what the common design practices should be for a change like that, so I was wondering if someone with more knowledge could include this functionality in the main codebase.
Thanks for sharing, it helped me!!
Have you found a solution to pass additional parameter to NMA like priority or content/type or whatever?
As mentioned in my first post I manually replaced a line in the source code for NMA. This allows priority to be sent, but it has to be done manually every time the code is updated. I was hoping someone would submit a pull request with that code because I don’t have time to do all the required things for that. I don’t know about content type though.
Yes, in fact my following pass will be to replace NMA component with a simple REST call to the NMA API.
