I just did a fresh install on a Debian 12 and after Configuration I am getting the error about non-priviledged Docker stuff (sorry, in GErman only):
Das System ist derzeit fehlerhaft, da es keinen privilegierten Zugriff auf die Docker-Laufzeit hat. Verwende den Link, um mehr zu erfahren und wie du dies beheben kannst.
When klicking on the provided link it is not really helpful as it is a fresh install, supported OS and latest version.
So what is the issue here and how do I get rid of it?
Iām affected by this issue as well. HASSIO complains about missing rights. docker inspect, however, reports Privileged is set for both hassio_supervisor and homeassistant.
In the same state: supervised install (2003.6.2) on Debian 12, and I am getting the āneed repairā notification.
I tried to update to 2012.6.2 and it would not let me due to āneeding repairā. I ran āha supervised repairā and the āneed repairā notification went away! I updated to 2023.6.3, installed latest updates to Debian and rebooted and I now have no issues.
I checked and only āhomeassistantā and āhassioā supervisorā dockers are āprivilegedā.
I just received this Privileged Docker Access Unhealty warning. I looked at the documentation and I did not find any instructions on how to deal with this (other than reinstall). What should I do now? Otherwise the system is totally healthy with no error messages anywhere. This is Debian Bookworm supervised, running only home assistant and nothing else of importance. All latest Debian, Docker and Home Assistant updates installed. The error message came suddenly out of the blue sky and I have made no changes to the system.
Make sure that your system still abide to the Supervised installation requirements and make sure you are running the latest OS-agent and have restarted your system after the update.
