I got frustrated enough to scratch an itch (editing files while HA is shut down), so here we go.
What this is
- The ability to ssh in to your OS so that you can edit any file, regardless of whether HA is running
What this is not
- Shell access to the underlying supervisor OS (for example, you can’t run
ha <anything>
that access can be gained if you have access to plugging a USB stick in to the machine, but that’s inconvenient for me since I’m running it in a VM) - A thoroughly-detailed guide. I’m skipping over some details.
Why bother then?
- Being able to copy/paste from my computer
nano
,jq
, and any other file editor you want to use (the container hasapk
) - Editing and removing entities from the entity registry
Executive summary
Run an openssh server inside a docker container
How
I personally added and edited all these files using the VS Code addon, but you’re welcome to use any other method. Nice bonus is that this is this is portable.
Create the folder we’ll use
Folder name openssh-server
This is all done in the config
folder, AKA CONFIG
(the main window) in VS Code, /mnt/data/supervisor/homeassistant/
from the console, /config
, or wherever else it’s stored. This is the folder with your configuration.yaml
file.
Double note: if you want access to the console from the CLI, log in to the cli then type login
. It (currently) opens an ash
shell
Example command: mkdir openssh-server && cd openssh-server
Add the helper files to the folder
run.sh
#!/bin/sh
docker run -d \
--name=openssh-server \
--hostname=openssh-server `#optional` \
-e PUID=1000 \
-e PGID=1000 \
-e TZ=<YOUR TIMEZONE> \
-e USER_NAME="<YOUR USERNAME>" \
-e PUBLIC_KEY="<YOUR PUBLIC KEY>" \
-e SUDO_ACCESS=true `#optional` \
-e PASSWORD_ACCESS=false `#optional` \
-p 2222:2222 \
-v /mnt/data/supervisor/homeassistant/openssh-server/config:/config \
-v /mnt:/mnt \
-v /mnt/data/supervisor:/hassio-supervisor-folder-mnt-data-supervisor \
--restart unless-stopped \
lscr.io/linuxserver/openssh-server
Note: you must specify a username other than root
end.sh
Used if you want to change the options in start.sh
: change them, run end.sh
, then start.sh
#!/bin/sh
echo "Stopping"
docker stop openssh-server
echo "'rm'ing"
docker rm openssh-server
start.sh
#!/bin/sh
docker start openssh-server
stop.sh
#!/bin/sh
Set it up
- Log in to the HA console and
cd
to the folder - Make all the files executable
chmod -x *.sh
Get it running
./run.sh
You should see something like this:
Success
You can now ssh -p 2222
from other machines directly in to the HA’s filesystem. Everything in /mnt/
is exposed in /mnt/
in the ssh
server, you can use sudo
to edit HA files, and you can access the config files in /mnt/data/supervisor/homeassistant/
(including the .storage
folder that is hidden from the VS Code addon)
I’ll consider this post a win if it helps at least one person
