I had quite a few issues with access after starting to use the new auth system. First, Iost access through nginx/duckdns (got a 403: Forbidden error when navigating to the HASS frontend, though I still had access to other components, e.g. HADashboard). Only on the duckdns address though, the local IP worked fine. I tried re-installing nginx/lets encrypt, with no success.
I tried deleting the .storage/auth , .storage/auth_provider.homeassistant and .storage/onboarding, and then nothing worked (I had to start over creating an admin user, but after that, HASS never loaded on any device, at any address). So I ended up with a complete re-install.
And now the exact same config as before works from my laptop on both local IP and duckdns address. But on my phone, I can now only access through my duckdns address. Using the local IP now gives the 403: Forbidden, that I previously saw when when navigating to my duckdns address. But only on my phone (tested both Chrome and Brave browsers, and I did try clearing cache/cookies), it works fine from both Chrome and Firefox on my laptop.
Any ideas what’s going on?
Did not think of that after a clean install…
I just had a similar problem which felt nearly impossible to troubleshoot. Your post provided the solution!
