Good day,
I have a Entities Card in which I would like to imbed two other cards. Right now, it does look like this:
I’m actually monitoring my Home Assistant docker image.
I would like to have a separation between the two graphs. Right now, those two are next to each other and when the graph lines are aligned, it looks like a single graph for two sensors (very weird).
Here is my lovelace yaml:
- type: entities
show_header_toggle: off
entities:
- type: section
label: Home-Assistant
- type: custom:vertical-stack-in-card
cards:
- type: horizontal-stack
cards:
- type: custom:mini-graph-card
entities:
- sensor.docker_home_assistant_cpu_use
height: 25
line_width: 2
font_size: 70
hours_to_show: 24
points_per_hour: 1
show:
extrema: true
fill: true
color_thresholds:
- value: 90
color: "#FFFF00"
- value: 80
color: "#1db954"
- value: 0
color: "#3498db"
entities:
- sensor.docker_home_assistant_memory_use_percent
height: 25
line_width: 2
font_size: 70
hours_to_show: 24
points_per_hour: 1
show:
extrema: true
fill: true
color_thresholds:
- value: 90
color: "#FFFF00"
- value: 80
color: "#1db954"
- value: 0
color: "#3498db"
I do not need to exactly follow what I’ve done… I was trying for the last two or three hours… The result I would like to have is a card in which I see two cards (with the borders, padding and shadow). A spacer could work too, depending on how it looks. A “divider” won’t work though… I’ve tried it!
Thank you for your help!
