2022-06-16 21:45:26 WARNING (MainThread) [pydeconz.models] Unsupported device type Unknown
2022-06-16 21:45:32 WARNING (MainThread) [homeassistant.setup] Setup of automation is taking over 10 seconds.
2022-06-16 21:45:34 WARNING (MainThread) [asyncio] socket.send() raised exception.
2022-06-16 21:45:34 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform mqtt is taking over 10 seconds.
2022-06-16 21:45:34 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform mqtt is taking over 10 seconds.
2022-06-16 21:45:54 WARNING (MainThread) [homeassistant.components.ps4.media_player] PS4 could not be reached
2022-06-16 21:57:00 ERROR (MainThread) [aiohttp.server] Unhandled exception
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1192, in _sendfile_fallback
read = await self.run_in_executor(None, file.readinto, view)
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 514, in start
resp, reset = await task
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 460, in _handle_request
reset = await self.finish_response(request, resp, start_time)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 613, in finish_response
await prepare_meth(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_fileresponse.py", line 286, in prepare
return await self._sendfile(request, fobj, offset, count)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_fileresponse.py", line 99, in _sendfile
await loop.sendfile(transport, fobj, offset, count)
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1171, in sendfile
return await self._sendfile_fallback(transport, file,
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1201, in _sendfile_fallback
await proto.restore()
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 268, in restore
self._transport.resume_reading()
File "/usr/local/lib/python3.9/asyncio/sslproto.py", line 343, in resume_reading
self._ssl_protocol._transport.resume_reading()
AttributeError: 'NoneType' object has no attribute 'resume_reading'
2022-06-16 22:17:12 ERROR (MainThread) [homeassistant.components.ipp.coordinator] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2022-06-16 22:20:33 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-16 22:20:33 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-06-16 22:20:33 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-16 22:20:33 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-16 22:20:33 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-16 22:20:33 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-16 22:20:33 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-16 22:20:33 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-16 22:20:33 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-16 22:20:33 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-16 22:20:33 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-16 22:20:33 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-16 22:20:33 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-16 22:20:33 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-16 22:20:33 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-16 22:20:33 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-16 22:25:44 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-16 22:25:44 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-16 22:25:44 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-16 22:25:44 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-16 22:25:44 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-16 22:25:44 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-16 22:25:44 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-16 22:25:44 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-16 22:25:44 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-16 22:25:44 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-16 22:25:44 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-16 22:25:44 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-16 22:25:44 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-16 22:25:44 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-06-16 22:25:44 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-16 22:25:44 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-16 22:30:55 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-16 22:30:55 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-16 22:30:55 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-16 22:30:55 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-16 22:30:55 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-16 22:30:55 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-16 22:30:55 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-16 22:30:55 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-06-16 22:30:55 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-16 22:30:55 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-16 22:30:55 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-16 22:30:55 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-16 22:30:55 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-16 22:30:55 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-16 22:30:55 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-16 22:30:55 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-16 22:36:07 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-16 22:36:07 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-06-16 22:36:07 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-16 22:36:07 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-16 22:36:07 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-16 22:36:07 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-16 22:36:07 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-16 22:36:07 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-16 22:36:07 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-16 22:36:07 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-16 22:36:07 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-16 22:36:07 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-16 22:36:07 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-16 22:36:07 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-16 22:36:07 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-16 22:36:07 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-16 22:41:19 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-16 22:41:19 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-16 22:41:19 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-16 22:41:19 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-16 22:41:19 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-16 22:41:19 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-16 22:41:19 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-16 22:41:19 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-16 22:41:19 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-16 22:41:19 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-16 22:41:19 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-16 22:41:19 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-16 22:41:19 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-16 22:41:19 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-16 22:41:19 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-16 22:41:19 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-06-16 22:46:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-16 22:46:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-06-16 22:46:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-16 22:46:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-16 22:46:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-16 22:46:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-16 22:46:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-16 22:46:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-16 22:46:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-16 22:46:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-16 22:46:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-16 22:46:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-16 22:46:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-16 22:46:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-16 22:46:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-16 22:46:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-16 22:51:42 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-16 22:51:42 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-16 22:51:42 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-16 22:51:42 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-16 22:51:42 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-16 22:51:42 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-06-16 22:51:42 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-16 22:51:42 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-16 22:51:42 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-16 22:51:42 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-16 22:51:42 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-16 22:51:42 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-16 22:51:42 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-16 22:51:42 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-16 22:51:42 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-16 22:51:42 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-16 22:56:53 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-16 22:56:53 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-06-16 22:56:53 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-16 22:56:53 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-16 22:56:53 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-16 22:56:53 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-16 22:56:53 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-16 22:56:53 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-16 22:56:53 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-16 22:56:53 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-16 22:56:53 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-16 22:56:53 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-16 22:56:53 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-16 22:56:53 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-16 22:56:53 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-16 22:56:53 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-16 23:02:04 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-16 23:02:04 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-16 23:02:04 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-16 23:02:04 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-16 23:02:04 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-16 23:02:04 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-16 23:02:04 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-16 23:02:04 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
... this occours all night
2022-06-17 08:53:35 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-17 08:53:35 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-17 08:53:35 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-17 08:53:35 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-17 08:53:35 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-17 08:53:35 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-17 08:53:35 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-17 08:53:35 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-17 08:53:35 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-17 08:53:35 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-17 08:53:35 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-17 08:53:35 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-17 08:53:35 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-17 08:53:35 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-17 08:58:46 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-17 08:58:46 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-06-17 08:58:46 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-17 08:58:46 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-17 08:58:46 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-17 08:58:46 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-17 08:58:46 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-17 08:58:46 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-17 08:58:46 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-17 08:58:46 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-17 08:58:46 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-17 08:58:46 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-17 08:58:46 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-17 08:58:46 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-17 08:58:46 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-17 08:58:46 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-17 09:03:58 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-17 09:03:58 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-17 09:03:58 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-17 09:03:58 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-17 09:03:58 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-17 09:03:58 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-06-17 09:03:58 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-17 09:03:58 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-17 09:03:58 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-17 09:03:58 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-17 09:03:58 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-17 09:03:58 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-17 09:03:58 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-17 09:03:58 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-17 09:03:58 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-17 09:03:58 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-17 09:09:09 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-17 09:09:09 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-17 09:09:09 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-17 09:09:09 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-06-17 09:09:09 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-17 09:09:09 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-17 09:09:09 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-17 09:09:09 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-17 09:09:09 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-17 09:09:09 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-17 09:09:09 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-17 09:09:09 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-17 09:09:09 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-17 09:09:09 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-17 09:09:09 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-17 09:09:09 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-17 09:14:20 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-06-17 09:14:20 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-06-17 09:14:20 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/243ffc37_pigpio/stats request
2022-06-17 09:14:20 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 243ffc37_pigpio:
2022-06-17 09:14:20 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-17 09:14:20 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-17 09:14:20 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2022-06-17 09:14:20 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_nodered:
2022-06-17 09:14:20 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-17 09:14:20 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-17 09:14:20 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-06-17 09:14:20 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-06-17 09:14:20 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-06-17 09:14:20 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-06-17 09:14:20 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2022-06-17 09:14:20 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_duckdns:
2022-06-17 09:17:13 ERROR (MainThread) [aiohttp.server] Unhandled exception
