Probems with clean install
hi all,
I’m hoping somebody can help me.
I have a Rasp Pi 3B+ with a 64gb Samsung micro SD card, 5v 3a power supply and ethernet cable for internet ( I plan to change this to wifi later). I’ve flashed the SD card with balenaEtcher plugged everything in, waited… gone to 192.168.0.32:8123 in chrome and seen the prepairing home assistant page… BUT… on there I get the following message flashing up, this has been going for about 18 hours now… any help?
thank you in advance .
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[15:51:38] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[15:51:39] INFO: Starting local supervisor watchdog...
Initializing Supervisor setup
Can't find Supervisor network, creating a new network
Initializing Supervisor Sentry
Creating Supervisor Add-on data folder at '/data/addons/data'
Attaching to Supervisor homeassistant/armv7-hassio-supervisor with version 249
Connecting Supervisor to hassio-network
Setting up Supervisor
Starting API on 172.30.32.2
Updating local host information
Updating service information
Updating local network information
Updating PulseAudio information
Loading AppArmor Profiles: {'hassio-supervisor'}
Reloading local service hassos-apparmor.service
Attaching to homeassistant/armv7-hassio-dns with version 9
Ignoring invalid DNS Server: dns://fdae:90b6:e6a2:0:3e89:94ff:fe51:bd68
Starting CoreDNS plugin
Starting DNS homeassistant/armv7-hassio-dns with version 9 - 172.30.32.3
Updated /etc/resolv.conf
Attaching to homeassistant/armv7-hassio-audio with version 17
Starting Audio plugin
Starting Audio homeassistant/armv7-hassio-audio with version 17 - 172.30.32.4
Attaching to homeassistant/armv7-hassio-cli with version 2020.10.0
Starting CLI plugin
Starting CLI homeassistant/armv7-hassio-cli with version 2020.10.0 - 172.30.32.5
Attaching to homeassistant/armv7-hassio-observer with version 2020.10.1
Starting observer plugin
Starting Observer homeassistant/armv7-hassio-observer with version 2020.10.1 - 172.30.32.6
Attaching to homeassistant/armv7-hassio-multicast with version 3
Starting Multicast plugin
Starting Multicast homeassistant/armv7-hassio-multicast with version 3 - Host
Fetching update data from https://version.home-assistant.io/stable.json
Loaded 0 Home Assistant secrets
No Home Assistant Docker image homeassistant/raspberrypi3-homeassistant found.
Setting up Home Assistant landingpage
Downloading docker image homeassistant/raspberrypi3-homeassistant with tag landingpage.
Starting HomeAssistant landingpage
Update pulse/client.config: /data/tmp/homeassistant_pulse
Starting Home Assistant homeassistant/raspberrypi3-homeassistant with version landingpage
Detect HassOS 4.15 / BootSlot A
Cloneing add-on https://github.com/hassio-addons/repository repository
Cloneing add-on https://github.com/home-assistant/hassio-addons repository
Loading add-ons from store: 66 all - 66 new - 0 remove
Found 0 installed add-ons
Found 0 snapshot files
Loaded 0 messages
Loaded 0 ingress sessions
Running Supervisor
Rauc: A - marked slot kernel.0 as good
Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
Phase 'AddonStartup.SYSTEM' starting 0 add-ons
Phase 'AddonStartup.SERVICES' starting 0 add-ons
Phase 'AddonStartup.APPLICATION' starting 0 add-ons
All core tasks are scheduled
Started Supervisor hardware monitor
Supervisor is up and running
Home Assistant setup
Updateing image homeassistant/raspberrypi3-homeassistant:landingpage to homeassistant/raspberrypi3-homeassistant:0.116.4
Downloading docker image homeassistant/raspberrypi3-homeassistant with tag 0.116.4.
Failed to load cookie file from cookie: No such file or directory
Have you tried re-flashing? or trying a different card?
That all looks ok. Try pressing Ctrl+F5 (refresh browser cache).
At 5am this morning I had a brainwave… the original problem was due to a power cut, so after hours of trying to get ha to reload without joy I decided to do a clean install… but I never won e checked my power supply… changed if over and withing 15 mins ha was up and running and I was loading my snapshot… so in short… busted power supply… thanks for all your help and time
