Problem accessing home assistant from internal network, DuckDNS
I have home assistant setup with duckdns. It works perfect when accessing my server from outside my network, but not when I’m in my own network (wifi). Anyone else experiencing the same issue?
Thanks in advance
DNSMasq. Create an internal A record that resolves to your inside IP.
Thanks, I’m afraid no luck. Using the IP of my machine works fine though, it’s just using the xxxx.duckdns.org adress doesn’t. I’m also using Adguard, could that conflict with the duckdns setup in any way?
This could be a hair pin issue on your ISP. You may be to use adguard filter to rewrite the external duckdns to homeassistant.local or whatever works for you internally.
I personally have an internal bind dns server running that provides split-horizon for my specific duckdns records
That did the trick! Many thanks @steriku !
