Running HassIO version 0.73.1 on Raspberry Pi 2. Everything runs great. However I added DuckDNS Add-on. The service is running OK but when adding the lines to the configuration.yaml file I am getting an error:
Invalid config for [http]: not a file for dictionary value @ data[‘http’][‘ssl_certificate’]. Got ‘/ssl/fullchain.pem’
not a file for dictionary value @ data[‘http’][‘ssl_key’]. Got ‘/ssl/privkey.pem’. (See /config/configuration.yaml, line 30). Please check the docs at https://home-assistant.io/components/http/
I am attaching the config.yaml file.configuration example.yaml (2.7 KB)
