I was trying to add an Esp32 Bluetooth Proxy sensor to ESPHome, I put in the ip address of my Home Assistant and use the default port of 6053 and click Submit in the GU. It gave me the following error:
Can’t connect to ESP. Please make sure your YAML file contains an ‘api:’ line.
I nc’ed the ip address and the port and it says “nc: connectx to 192.168.1.184 port 6053 (tcp) failed: Connection refused”. There is an ‘api’ in the yaml file though. I do however have another Bluetooth Proxy running without any problem.
Your suggestions are gratefully appreciated. thanks1
James
