Problem afte HA OS 10 upgrade
I’m using HASSIO on RPI3b and Samsung 128GB usb key. Recently I’ve updated Hassio to OS 10. The RPI3 cannot boot anymore form USB.
I’ve tried to format USB and install back 9.5 but I got same error.
Formatting the Samsung usbkey with Raspbian it has been able to boot.
I’ve also changed usb to an old 16GB and it .
this is the log:
Net:
starting USB…
Bus usb@7e980000: USB DUC2
scanning bus usb@7e980000 for devices… error in inquiry
4 USB Device found
scanning usb for storage devices... 0 Storage Device(s) found
WARNING at drivers/nmc/bcm2835_ sdhost.c:414/bcm2835_send_connand()!
WARNING at drivers/nnc/bcn2835_sdhost.c:414/bcm2835_send_connand()!
Card did not respond to voltage selectf : -110
Card did not respond to uoltage selectt : -110
NNC Device 2 not found
no nnc device at slot GS
Device 0: unknon device
missing environnent variable: pxeuuid
Retrieving file: pxelinux.cfg/01-b8-27-eb-9e-65-66
Retrieving file: pxelinx.cfg/00000000
Retrieving file: pxelinux.cfg/0000000
Betrieving file: pxelinux.cfg/0000
Retrieviny file: pxelinux.cfg/000
Retricuing file: pxelinux.cfg^0
Retrieving file: pxelinux.cfg/default-arn-bcm283x-rpi
Config file not found
