Problem after updating to 0.62
I can’t boot my HA in Hass.io on a RPi model B after doing the automatic update requested for HA.
This is my log:
2018-01-29 22:04:35 ERROR (SyncWorker_0) [homeassistant.util.yaml] while parsing a block mapping
in “/config/configuration.yaml”, line 1, column 1
expected , but found ‘’
in “/config/configuration.yaml”, line 131, column 2
2018-01-29 22:04:35 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: while parsing a block mapping
Is there any way to recover HA?
Probably something to do with " and '. I had similar problems. Look for something like this:
value_template: '{{ states('light.plamp01_brightness') | int > 253 }}'
and change it into:
value_template: "{{ states('light.plamp01_brightness') | int > 253 }}"
I have already commented line 131 to discard that… the problem is that I can’t start home assistant and I can´t get it to web on port 8123.
Next log after change the line 131:
2018-01-29 22:35:52 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2018-01-29 22:38:28 WARNING (MainThread) [homeassistant.components.vacuum] Setup of platform xiaomi_miio is taking over 10 seconds.
2018-01-29 22:38:29 ERROR (MainThread) [homeassistant.components.vacuum] Error while setting up platform xiaomi_miio
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py”, line 189, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File “/usr/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
raise self._exception
File “/usr/lib/python3.6/asyncio/tasks.py”, line 180, in _step
result = coro.send(None)
File “/usr/lib/python3.6/asyncio/coroutines.py”, line 210, in coro
res = func(*args, **kw)
File “/usr/lib/python3.6/site-packages/homeassistant/components/vacuum/xiaomi_miio.py”, line 90, in async_setup_platform
from miio import Vacuum
File “/usr/lib/python3.6/site-packages/miio/init.py”, line 2, in
from miio.protocol import Message, Utils
File “/usr/lib/python3.6/site-packages/miio/protocol.py”, line 179, in
Const(0x2131, Int16ub),
File “/usr/lib/python3.6/site-packages/construct/core.py”, line 1894, in init
super(Const, self).init(subcon)
File “/usr/lib/python3.6/site-packages/construct/core.py”, line 291, in init
raise TypeError(“subcon should be a Construct field”)
TypeError: subcon should be a Construct field
2018-01-29 22:39:25 WARNING (SyncWorker_2) [netdisco.ssdp] Error fetching description at 192.168.1.115
2018-01-29 22:56:47 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
