After upgrade to latest firmware ember my zigbee won’t start.
What goes wrong here ?
[10:35:30] INFO: Preparing to start…
[10:35:30] INFO: Socat not enabled
[10:35:32] INFO: Starting Zigbee2MQTT…
Starting Zigbee2MQTT without watchdog.
[2024-09-24 10:35:38] info: z2m: Logging to console, file (filename: log.log)
[2024-09-24 10:35:38] info: z2m: Starting Zigbee2MQTT version 1.39.1 (commit #unknown)
[2024-09-24 10:35:38] info: z2m: Starting zigbee-herdsman (0.55.3)
[2024-09-24 10:35:38] info: zh:ember: Using default stack config.
[2024-09-24 10:35:38] info: zh:ember: ======== Ember Adapter Starting ========
[2024-09-24 10:35:38] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-09-24 10:35:38] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-09-24 10:35:38] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-09-24 10:35:38] info: zh:ember:uart:ash: Serial port opened
[2024-09-24 10:35:38] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-09-24 10:35:41] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-09-24 10:35:41] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-09-24 10:35:43] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-09-24 10:35:43] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-09-24 10:35:46] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-09-24 10:35:46] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-09-24 10:35:48] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-09-24 10:35:48] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-09-24 10:35:51] error: z2m: Error while starting zigbee-herdsman
[2024-09-24 10:35:51] error: z2m: Failed to start zigbee
[2024-09-24 10:35:51] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-09-24 10:35:51] error: z2m: Exiting…
[2024-09-24 10:35:51] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:746:19)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1758:24)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:127:29)
at Zigbee.start (/app/lib/zigbee.ts:63:27)
at Controller.start (/app/lib/controller.ts:139:27)
at start (/app/index.js:154:5)
