Hello, I am having problems with my temperature and humidity sensors model AS008 Aqara, the obtained temperature has an accuracy of 0.5 degrees, is there any way to modify the reading to 0.1 degrees of precision?
Hi Raúl, do you found a solution for the precision issue?
