Problem bith switch cortaine of tuya
I have a new curtain switch of Tuya and in the integration with Home Assistant it has been detected as a normal switch in which I can only raise the blind. Can you help me?
It doesn’t work, it seems that Hassio recognizes the blind switch as a light switch, it only works to go up.
I have the same issue.
My curtain switches are fine, but tuya integration is giving problems since three days ago. Everything operates, but they are extremelyyyyy slow to update status.
What model do you have? I have this and I can only raise the blid with Home Assistant.
It is the same model that I have.
Google home detects it as a plug.
Mine are different, is a wall model.
I have the same issue. Have you solve it?
Somebody have solution ??
Thank you
Same probleme here!
i also have one of the one of JorgeMaTeixeira
that’s wprking fine en now i have 5 built in model and only a switch.
Í’ve there is no solution i will flash them with tasmota but tuya app will not work anymore as fallback.
Same issue here.
Any solution?
