Hi everyone! I am using a sonoff dongle as a thread border router, the light example from esp-matter flashed into an esp32-c6, and basically I am trying to commission it to ha. I have the matter server add-on installed, the silicon labs multiprotocol to create the thread network, and I added a script to ha to be able to sync the thread credentials into my ios (which seems to be working fine). When I start the commissioning process everything starts fine, I click on add anyway, it says its in the process of “Setting up” but then takes to long to set up and gives me a message saying “Unable to Add accessory”. I checked the IP:8080 → topology and the thread network is created fine, the esp is able to join the thread network however it is not added to home assistant devices.
I also tested matter over wi-fi previously and it worked fine.
Does anyone have any idea of what I can do to fix this problem?
On the matter server add-on logs I get these errors:
“2024-05-13 11:21:16.428 (Dummy-2) CHIP_ERROR [chip.native.DL] Long dispatch time: 215 ms, for event type 2”
[1715530694.803271][238:238] CHIP:DL: Found the primary Ethernet interface:enp0s3
[1715530694.804046][238:238] CHIP:DL: Failed to get WiFi interface
[1715530694.804104][238:238] CHIP:DL: Failed to reset WiFi statistic counts
2024-05-12 17:18:14.804 (MainThread) WARNING [PersistentStorage] Initializing persistent storage from file: /data/chip.json
2024-05-12 17:18:14.804 (MainThread) WARNING [PersistentStorage] Loading configuration from /data/chip.json…
