Since my update was from 2022.3.x, it could have been any version between?
If I compile with the esphome section of the device’s YAML as follows, compilation fails with multiple errors that suggest mis-matches between various bits of code:
esphome:
comment: '${device_description}'
platform: ESP32
board: nodemcu-32s
platformio_options:
platform: espressif32
board: az-delivery-devkit-v4
board_build.mcu: esp32
board_build.f_cpu: 240000000L
Commenting out the platformio options allows the YAML to compile, be flashed to the device and run properly.
I guess I do have a workaround (don’t specify the options), however, I feel like the options should be right.
Thanks!
Resulting messages from compilation:
INFO Reading configuration /config/esphome/cat_locator.yaml...
WARNING 'cat_locator': Using the '_' (underscore) character in the hostname is discouraged as it can cause problems with some DHCP and local name services. For more information, see https://esphome.io/guides/faq.html#why-shouldn-t-i-use-underscores-in-my-device-name
WARNING GPIO2 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO4 is a Strapping PIN and should be avoided.
INFO Generating C++ source...
INFO Compiling app...
Processing cat_locator (board: az-delivery-devkit-v4; framework: arduino; platform: espressif32)
HARDWARE: ESP32 240MHz, 520KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- AsyncTCP-esphome @ 1.2.2
|-- WiFi @ 1.0
|-- FS @ 1.0
|-- Update @ 1.0
|-- ESPAsyncWebServer-esphome @ 2.1.0
|-- DNSServer @ 1.1.0
|-- ESPmDNS @ 1.0
|-- noise-c @ 0.1.4
| |-- libsodium @ 1.10018.1
|-- ArduinoJson @ 6.18.5
Compiling /data/cat_locator/.pioenvs/cat_locator/src/esphome/components/api/api_connection.cpp.o
Compiling /data/cat_locator/.pioenvs/cat_locator/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/cat_locator/.pioenvs/cat_locator/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/cat_locator/.pioenvs/cat_locator/src/esphome/components/api/api_pb2_service.cpp.o
In file included from /data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/xtensa-esp32-elf/no-rtti/bits/gthr.h:151,
from /data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/ext/atomicity.h:35,
from /data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/bits/basic_string.h:39,
from /data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/string:52,
from src/esphome/core/component.h:3,
from src/esphome/components/api/proto.h:3,
from src/esphome/components/api/api_pb2.h:5,
from src/esphome/components/api/api_pb2.cpp:3:
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/xtensa-esp32-elf/no-rtti/bits/gthr-default.h: In function 'int __gthread_mutex_timedlock(__gthread_mutex_t*, const __gthread_time_t*)':
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/xtensa-esp32-elf/no-rtti/bits/gthr-default.h:781:12: error: 'pthread_mutex_timedlock' was not declared in this scope
return __gthrw_(pthread_mutex_timedlock) (__mutex, __abs_timeout);
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/xtensa-esp32-elf/no-rtti/bits/gthr-default.h:781:12: note: suggested alternative: 'pthread_mutex_trylock'
In file included from /data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/cstdlib:75,
from /data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/ext/string_conversions.h:41,
from /data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/bits/basic_string.h:6400,
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/sys-include/stdlib.h: At global scope:
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/sys-include/stdlib.h:94:44: error: expected initializer before '__result_use_check'
void *calloc(size_t, size_t) __malloc_like __result_use_check
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/sys-include/stdlib.h:112:36: error: expected initializer before '__result_use_check'
void *malloc(size_t) __malloc_like __result_use_check __alloc_size(1) _NOTHROW;
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/sys-include/stdlib.h:157:31: error: expected initializer before '__result_use_check'
void *realloc(void *, size_t) __result_use_check __alloc_size(2) _NOTHROW;
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/sys-include/stdlib.h:159:44: error: expected initializer before '__result_use_check'
void *reallocarray(void *, size_t, size_t) __result_use_check __alloc_size2(2, 3);
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/sys-include/stdlib.h:160:32: error: expected initializer before '__result_use_check'
void *reallocf(void *, size_t) __result_use_check __alloc_size(2);
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/sys-include/stdlib.h:301:6: error: expected initializer before '__result_use_check'
__result_use_check;
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/sys-include/stdlib.h:344:52: error: expected initializer before '__alloc_align'
void * aligned_alloc(size_t, size_t) __malloc_like __alloc_align(1)
In file included from /data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/ext/string_conversions.h:41,
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/cstdlib:144:11: error: '::calloc' has not been declared
using ::calloc;
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/cstdlib:151:11: error: '::malloc' has not been declared
using ::malloc;
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/cstdlib:164:11: error: '::realloc' has not been declared
using ::realloc;
from src/esphome/components/api/api_pb2_service.h:5,
from src/esphome/components/api/api_pb2_service.cpp:3:
__result_use_check;
using ::calloc;
using ::malloc;
using ::realloc;
from src/esphome/components/socket/socket.h:2,
from src/esphome/components/api/api_frame_helper.h:13,
from src/esphome/components/api/api_frame_helper.cpp:1:
__result_use_check;
using ::calloc;
using ::malloc;
using ::realloc;
from src/esphome/components/api/api_connection.h:3,
from src/esphome/components/api/api_connection.cpp:1:
__result_use_check;
using ::calloc;
using ::malloc;
using ::realloc;
In file included from src/esphome/components/api/proto.h:5,
src/esphome/core/helpers.h: In member function 'T* esphome::ExternalRAMAllocator<T>::allocate(size_t)':
src/esphome/core/helpers.h:618:30: error: there are no arguments to 'malloc' that depend on a template parameter, so a declaration of 'malloc' must be available [-fpermissive]
ptr = static_cast<T *>(malloc(size)); // NOLINT(cppcoreguidelines-owning-memory,cppcoreguidelines-no-malloc)
src/esphome/core/helpers.h:618:30: note: (if you use '-fpermissive', G++ will accept your code, but allowing the use of an undeclared name is deprecated)
In file included from src/esphome/components/api/api_frame_helper.cpp:5:
from src/esphome/components/api/api_connection.h:4,
*** [/data/cat_locator/.pioenvs/cat_locator/src/esphome/components/api/api_pb2_service.cpp.o] Error 1
*** [/data/cat_locator/.pioenvs/cat_locator/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
*** [/data/cat_locator/.pioenvs/cat_locator/src/esphome/components/api/api_pb2.cpp.o] Error 1
*** [/data/cat_locator/.pioenvs/cat_locator/src/esphome/components/api/api_connection.cpp.o] Error 1
========================== [FAILED] Took 9.37 seconds ==========================
