I’m new to Home Assistant. I got it up and running generally, but I am having a problem with Lutron.
I had an installer setup my lights, shades, etc., with a Lutron RA2 and a Lutron Connect Bridge. I have about a dozen lights and 5 shades. I am using HA v 2022.11.3.
Home Assistant sees the Lutron Connect Bridge, and lists 1 device and 1 entity – namely, the Bridge. It does not see or otherwise set up any other Lutron stuff. (I did read the documentation, and I realize it is supposed to set up the switches as events rather than devices, but I’m getting nothing.)
I went through the configure process, and I put in the xxx-xx-xxx code from my Bridge to get it paired. But I am getting an error saying that it couldn’t start Lutron. I also went into the configuration.yaml and added the following:
Lutron configuration
lutron:
host: 192.168.1.196
username: [my e-mail]
password: [my password]
I suspect I’m doing something wrong in this configuration. First, for the host, am I supposed to use the Bridge’s IP address or the RA2’s IP address? When I try the Bridge’s IP address, I get a configuration error, but if I use the RA2, I get an uncaught exception error. In both cases, Lutron doesn’t seem to be loading up in HA.
I also note that the config file is supposed to have a Username, but my installer set up my system with the username blank,although there is an e-mail address and a password. If I go into a web browser and type in the RA2’s IP address, the Login page accepts my e-mail address as the user name. So, I have tried the configuration.yaml file with the user name blank and with my e-mail address, and neither are working.
Here is the error log I get when I use the e-mail address as the user name and the RA2 IP address as the host, let me know if I should post the errors for any other combination:
# Lutron configuration
2022-11-17 05:44:12.308 ERROR (Thread-2) [pylutron] Uncaught exception
File "/usr/local/lib/python3.10/site-packages/pylutron/__init__.py", line 171, in _main_loop
self._maybe_reconnect()
File "/usr/local/lib/python3.10/site-packages/pylutron/__init__.py", line 158, in _maybe_reconnect
self._do_login_locked()
File "/usr/local/lib/python3.10/site-packages/pylutron/__init__.py", line 133, in _do_login_locked
self._telnet.read_until(LutronConnection.PROMPT, timeout=3)
File "/usr/local/lib/python3.10/telnetlib.py", line 329, in read_until
return self.read_very_lazy()
File "/usr/local/lib/python3.10/telnetlib.py", line 405, in read_very_lazy
raise EOFError('telnet connection closed')
EOFError: telnet connection closed
Thanks!
