Hello. I’m having a problem almost every day where my connection to home assistant using https through duckdns fails. I can connect locally, but through the DNS name I can’t. I don’t change anything and after an hour or so, it starts working again. Sometimes it takes much more time. I’m using port forwarding on my router, and it seems it’s reaching. Could it be the duckdns that is failing? I’m not sure how to diagnose.
Duckdns is not very stable recently.
Thank you. Do you know of an alternative to Duckdns?
