when I create my docker file.
ARG BUILD_FROM
FROM $BUILD_FROM
ENV LANG C.UTF-8
RUN apk add --no-cache nodejs nodejs-npm
RUN mkdir -p /app
RUN cd /app
COPY package.json /app/package.json
RUN npm install --save
WORKDIR /app
COPY . /app
EXPOSE 8080
# Copy data for add-on
#COPY run.sh /
RUN chmod a+x /app/run.sh
CMD [ "/app/run.sh" ]
the npm install create a directory in /app/node_modules
I think, when docker builds the image, the node_modules directory is created within the app directory, and all the dependencies are installed there. Then on runtime the worker directory from outside docker is mounted into the docker instance (which does not have the installed node_modules), hiding the node_modules you just installed.
how can I solve it?
I`m trying with ENV NODE_PATH butIi can’t find the solution.
thanks
Pd. More info in https://stackoverflow.com/questions/30043872/docker-compose-node-modules-not-present-in-a-volume-after-npm-install-succeeds
