Problem creating an automation using Yale Lock to arm alarm
Hello… I’m a new user here and just getting my feet wet with Home Assistant. I love the platform so far, and am still coming up to speed.
I’m experimenting with different automations, and would like to create one to arm my Simplisafe Alarm when I lock my Yale Lock from the outside. I’ve created the following automation, but it only works when I lock the Yale Lock via my Home Assistant Dashboard. When I lock it using the keypad, manual deadbolt or Yale App, nothing happens. (I actually don’t want it to arm when locking the deadbolt manually from the inside). Once I have this working, I would like to do the same thing to disarm the alarm when I unlock the door.
Here is my current automation:
alias: Yale Lock Arm Alarm
description: ""
  - platform: state
    entity_id:
      - lock.front_door_lock
    to: locking
condition:
  - condition: state
    entity_id: alarm_control_panel.alarm_control_panel
    state: disarmed
  - service: alarm_control_panel.alarm_arm_away
      device_id: 4555c9x8478fx4b6665562x3232x4b3a
    data: {}
mode: single
What am I doing wrong?
When locked from outside home assistant does the state change to locking, or does it just go straight to locked. Check the entity history.
You are on to something here. Looking at the entity history it just goes to locked. However, the automation does trigger when I use the HA dashboard. I wonder if HA is smart enough to know it’s locking and triggers it.
I can change the automation to use locked, but then I have another issue. The alarm will arm anytime the state changes to locked, which could be triggered by me locking the deadbolt manually from the inside. Obviously, I don’t want to arm the alarm with me in the house. I wonder if there is a way to avoid that?
OK, I think I have it figured out. There is another entity called front_door_lock.operator That tracks the difference between a manual lock/unlock and one completed using the keypad. I need to figure out how to code it now. Will report back.
Does this code make sense?
alias: Lock Arm Alarm
  - platform: state
    entity_id:
    to: locked
condition:
  - condition: state
    state: disarmed
  - condition: and
    conditions:
      - condition: state
        entity_id: sensor.front_door_lock_operator
        attribute: keypad
        state: ""
      device_id: 4555c9x8478fx4x6789562b3232a4b3a
    data: {}
mode: single
Not quite. Conditions are AND logic by default. So this is all you need:
condition:
  - condition: state
    state: disarmed
  - condition: state
    attribute: keypad
    state: ""
And are you sure the keypad state is null only when you lock it manually?
Also try to use entity ids instead of device ids. It will save you hassle later (the action).
I’m not sure if it should be null to be honest… Here is the entity history
When I lock with the keypad the Operator is “One Touch Lock” so ideally, I want to say:
[When state changes from Unlocked to Locked AND Operator is One Touch Lock, arm the alarm.]
However, I’m not great with code, so still figuring out that part.
Conversely, I need to do the same to disarm the alarm, so something like…
[When state changes from Locked to Unlocked AND Operator is NOT Manual Unlock, arm the alarm]
I just need to figure out how to write that in YAML and I should be good to go.
In case it helps, these are the options I can see under Front Door Lock Operator…
Those are attributes. You don’t want an attribute value. You just want the state.
condition:
  - condition: state
    state: disarmed
  - condition: state
    state: "One-Touch Lock"
OK Awesome… Let me try that. Thanks!
OK, I’ve updated the code… Now for the one to disarm the alarm. This is a bit more tricky. The easy option is to just have the alarm disarm when the state changes from Locked to Unlocked and not worry about the Operator. However, that could cause an issue if someone were to break in via a window, and just unlock the deadbolt manually, it would disarm the alarm…
Ideally, I’d like to have multiple options for the condition, something like…
If sensor.front_door_lock_operator is “Matt” disarm alarm with code 1234
If sensor.front_door_lock_operator is “Erica” disarm alarm with code 5678
If sensor.front_door_lock_operator is “Billy” disarm alarm with code 9101
I know I can write the action like this:
  - service: alarm_control_panel.alarm_disarm
      device_id: 4555c9e8478fbxb42225562b3232a4b3a
      code: "1234"
mode: single
But how do I write the code to link each condition with a different action? Should they be separate automations for each one, but each with the same trigger?
Here’s one way:
alias: Lock Disarm Alarm
  - platform: state
    entity_id:
    to: unlocked
  - if:
      - condition: state
        state: Matt
    then:
          code: "1234"
  - if:
      - condition: state
        state: Erica
    then:
          code: "5678"
  - if:
      - condition: state
        state: Billy
    then:
          code: "9101"
mode: single
I really appreciate all your help. I still don’t quite have the “lock” scenario working yet. Not sure why but the arming of the alarm isn’t being triggered.
I’m wondering if the “One-Touch Lock” should be in quotes or not, or if that is actually what the state is called. I know that’s what it shows in the History page, but wonder if it’s flagged as something else behind the scenes. Any ideas?
I took the state from your screenshot of the history graph. To see the actual state go to Developer Tools → States and look for your sensor.front_door_lock_operator entity.
You can filter on strings at the top of the columns to make it easier to find.
I figured it out… So, I now have the lock part working. I actually changed the YAML to trigger the arming of the alarm based on the sensor.front_door_lock_operator like this:
  - platform: state
    entity_id:
      - sensor.front_door_lock_operator
    to: One-Touch Lock
condition:
  - condition: state
    state: disarmed
      device_id: 4555c9e8478fx4x6665562x3232x4b3a
    data: {}
mode: single
So, the lock/arm automation works. Now I need the unlock/disarm automation to work. This is what I have so far, but it isn’t working. I must be missing something.
  - platform: state
    entity_id:
    to: Matt
  - platform: state
    entity_id:
    to: Billy
condition:
  - condition: state
    state: armed_away
      device_id: 4555c9e8478fx4x7765562b3232x4b3a
      code: "0000"
mode: single
I checked out the link and it was helpful. Used the trace, and it appears my automation was triggered and did actually run, it just also appears that the alarm didn’t disarm. Maybe I need to wait a few seconds longer to give it time to react. I’ll try again tomorrow and circle back with an update.
Finally got to work on this again after the holidays, and got it working…
description: ""
  - platform: state
    entity_id:
    to: Matt
condition: []
      device_id: 44567c9e8478fb4b6667862b3242a4s3a
      code: "0000"
mode: single```
