dubbfredda
(Fredrik Jacobsson)
November 11, 2022, 12:31pm
1
I try to create multiples dashboards in lovelace.
Today I have a yaml dashboard and would like to change to a main UI dashboard with additional yaml dashboards.
According to the example from the manual you should be able to do that.
But I can’t get it to work.
I have following code in the configuration.yaml file.
The syntax seems to be right, no error.
But it don’t seems to read my yaml-files. If I change the files, nothing changes.
And I can’t use the “Edit Dashboard” menu. Get following error
Do anyone see what I’m doing wrong ?
Heinz
November 11, 2022, 1:04pm
2
Maybe the path to your yaml-files is wrong. Did you try it (for testing purpose) with file(s) located directly in config-folder?
HasQT
(Has)
November 11, 2022, 1:27pm
3
Is that error coming up when you try to edit your main dashboard or a yaml dashboard?
That image you linked says you can also use yaml dashboards.
It doesn’t say you can edit the yaml dashboards via the UI editor…
Why not just make UI dashboards via settings > dashboards?
dubbfredda
(Fredrik Jacobsson)
November 11, 2022, 2:09pm
4
Well the only message I get is the last picture I attached.
Saying that I have yaml mode activated which I believed I hade deactivated in the configuration.yaml file.
I don’t what to edit my yaml dashboad via the UI editor. I only would like to edit my main UI dashboard with the editor. And the yaml dashboard will I continue to edit in a text editor.
HasQT
(Has)
November 11, 2022, 3:02pm
5
This works for me.
I can edit the main dash
The switches dash gives the edit UI is not available in yaml mode.
Did you try a restart after changing yaml mode to storage on the main dash.
lovelace:
mode: storage
dashboards:
lovelace-switches:
mode: yaml
title: Switches
icon: mdi:dip-switch
show_in_sidebar: true
filename: /config/lovelace_views/lovelace-switches.yaml
dubbfredda
(Fredrik Jacobsson)
November 12, 2022, 3:49pm
6
@HasQT now I haven’t try to restart, will do that!
One other question. Do I need a ui-lovelace.yaml file, main file in the config-folder.
If I do, what should it include.
I would like to split my other yaml-files into different files in a seperate folder, lovelace_views.
HasQT
(Has)
November 12, 2022, 4:09pm
7
You mean an !include ?
!include file_for_lovelace.yaml
So that this wouldn’t be in configuration.yaml?
lovelace:
mode: storage
dashboards:
lovelace-switches:
mode: yaml
title: Switches
Or do you mean a separate file for switches dash and sauna? It will currently be a separate file the way you have it set it. lovelace-sauna.yaml
dubbfredda
(Fredrik Jacobsson)
November 14, 2022, 7:48am
8
I started with one yaml-file, ui-lovelace.yaml in my config folder.
All my lovelace configuration in that file.
But now I would like to have the main dashboard as UI and my additional dashboard as yaml. And the additional dashboards would I all like to slip into different files.
Now the question is what I should do with my old ui-lovelace.yaml file?
If I don’t split the yaml configuration in to separate files, should the yaml dashboard be in the ui-lovelace.yaml file?
And what happens with the ui-lovelace.yaml file when I split the yaml-configurations into separate files?
HasQT
(Has)
November 14, 2022, 9:15am
9
Make a backup of your current setup.
Your old lovelace file should have been converted to UI and stored in the .storage as json
/config/.storage/lovelace
It would be best to confirm that.
That should make your existing ui-lovelace.yaml redundant. So you can delete that file.
It would be best to check and have a backup for that…
The way you are setting it up currently is for splitting into separate files into lovelace_views
folder
dubbfredda
(Fredrik Jacobsson)
November 14, 2022, 10:04am
10
I don’t have “/config/.starage/lovelace”.
See picture
But I did a local copy of the ui-lovelace.yaml file.
Now I the main UI dashboard is working.
Not configured yet…but working
I can edit the dashboard by the “Edit dashboard” menu.
Moved my yaml dashboard (lovelace-switches.yaml) to the main config folder, see picture above from the configuration.yaml file.
But the yaml dashboard want show up in the sidebar or the top menu.
Does lovelace-switches.yaml have the correct syntax ?
HasQT
(Has)
November 14, 2022, 10:45am
11
You haven’t made it visible.
.storage is a hidden directory
It is also easy to break HA if you mess around in .storage
Hard to say if your syntax is correct.
You would need to post your code in codeblock </> or backticks ```
Try that and go from there.
title: Home
- path: default_view
title: Home
cards:
- type: entities
entities:
- person.bob
- type: grid
square: false
columns: 1
cards:
- type: media-control
entity: media_player.family_room
entity: media_player.home_group
- type: weather-forecast
entity: weather.forecast_home
show_forecast: false
- theme: Backend-selected
dubbfredda
(Fredrik Jacobsson)
November 14, 2022, 11:48am
12
Can’t see switches or sauna dashboards
This is who my configuration.yaml file looks like
# Lovelace frontend
lovelace:
# mode: yaml
mode: storage
dashboards:
lovelace-switches:
mode: yaml
title: Switches
filename: lovelace-switches.yaml
lovelace-sauna:
mode: yaml
title: Sauna
filename: lovelace-sauna_view.yaml
#### Switches view ####
title: Switches
- icon: mdi:light-switch
#id: switch
title: Switches
cards:
- type: vertical-stack
cards:
- type: entities
title: Wall plugs 433MHz
show_header_toggle: true
entities:
- entity: switch.ac_1877bfe_16
name: Livingroom window light (wall plug1)
icon: mdi:power-socket-eu
state_color: true
- entity: switch.ac_1877bfe_15
name: Livingroom window light (wall plug2)
state_color: true
- entity: switch.ac_1877bfe_14
name: Alva window light (wall plug3)
state_color: true
- entity: switch.ac_1877bfe_13
name: TV light (wall plug4)
state_color: true
- entity: switch.ac_1ababfe_16
name: Meja window light (wall plug5)
state_color: true
- entity: switch.ac_1ababfe_15
name: Alva mirror light (wall plug6)
state_color: true
- entity: switch.ac_1ababfe_14
name: Meja mirror light (wall plug7)
state_color: true
- entity: switch.ac_1ababfe_13
name: Wall plug 8
- entity: switch.ac_1646b2e_16
name: Wall plug 9
state_color: true
- entity: switch.ac_1646b2e_15
name: Wall plug 10
state_color: true
- entity: switch.ac_1646b2e_14
name: Wall plug 11
state_color: true
- entity: switch.ac_1f5e6f6_3
name: Wall plug out 1
state_color: true
cards:
- type: entities
title: Switches Zwave
entities:
- entity: switch.flush_2_relay_3
icon: mdi:track-light
state_color: true
- entity: switch.flush_2_relay_4
state_color: true
# - entity: switch.fibaro_system_fgs223_double_relay_switch
# icon: mdi:track-light
# state_color: true
# - entity: switch.fibaro_system_fgs223_double_relay_switch_2
# state_color: true
# - entity: switch.fibaro_system_fgs223_double_relay_switch_3
# icon: mdi:outdoor-lamp
# state_color: true
# - entity: switch.fibaro_system_fgs223_double_relay_switch_4
# state_color: true
# - entity: switch.fibaro_system_fgs223_double_relay_switch_6
# state_color: true
# - entity: switch.fibaro_system_fgs223_double_relay_switch_9
# state_color: true
- type: entities
title: Wall plugs Zwave
entities:
- entity: switch.fibaro_system_fgwpe_f_wall_plug_switch
name: Computer wall plug
state_color: true
- entity: sensor.fibaro_system_fgwpe_f_wall_plug_power
- entity: sensor.fibaro_system_fgwpe_f_wall_plug_energy
- entity: sensor.fibaro_system_fgwpe_f_wall_plug_exporting
- type: entities
title: Wall plugs Zigbee
entities:
- entity: switch.tvligtht_tradfrioutlet1
name: TV light (Zigbee wall plug1)
state_color: true
cards:
- type: entities
title: Enable Automation
show_header_toggle: false
entities:
- entity: input_boolean.switch_at_home
- entity: input_boolean.switch_kitchen_win_light_en
- entity: input_boolean.switch_facade_light_en
- entity: input_boolean.switch_hallway_win_light_en
- entity: input_boolean.switch_stairs_win_light_en
- entity: input_boolean.switch_dining_win_light_en
- entity: input_boolean.switch_alva_win_light_en
- entity: input_boolean.switch_tv_light_en
- entity: input_boolean.switch_meja_win_light_en
- entity: input_boolean.switch_alva_mirror_light_en
- entity: input_boolean.switch_meja_mirror_light_en
- entity: input_boolean.switch_wallplug8_en
- entity: input_boolean.switch_wallplug9_en
- entity: input_boolean.switch_wallplug10_en
- entity: input_boolean.switch_wallplug11_en
- entity: input_boolean.switch_wallplug_out1_en
title: Sauna
title: Sauna
cards:
- type: horizontal-stack
cards:
card:
type: entities
title: Sauna lights
entities:
- entity: switch.flush_2_relay_2_2
card:
type: entities
title: LED-light
entities:
- light.rgbw_controller
- light.rgbw_controller_2
- light.rgbw_controller_2_2
- light.rgbw_controller_3
- light.rgbw_controller_4
- light.rgbw_controller_5
card:
type: entities
title: Sauna control
entities:
- entity: input_boolean.switch_sauna_on_off
- entity: input_boolean.switch_sauna_auto_en
- entity: input_number.slider_sauna_hour
- entity: input_number.slider_sauna_minutes
card:
type: gauge
title: Sauna Temp
entity: sensor.flush_2_relay_air_temperature
min: 10
max: 100
theme: default
severity:
green: 0
yellow: 30
red: 50
dubbfredda
(Fredrik Jacobsson)
November 14, 2022, 11:59am
13
My mistake
I can’t edit the dashboard from the “Edit dashboard” menu.
Get this message when I try to edit the dashboard
I guess this mean that I don’t have the right configuration to enable the main UI dashboard.
HasQT
(Has)
November 14, 2022, 12:01pm
14
Have you done a restart since you added this?
# Lovelace frontend
lovelace:
# mode: yaml
mode: storage
dashboards:
lovelace-switches:
mode: yaml
title: Switches
lovelace-sauna:
mode: yaml
title: Sauna
This had some errors.
lovelace-sauna_view.yaml - fixed
title: Sauna
title: Sauna
cards:
cards:
cards:
- type: entities
title: Sauna lights
entities:
- type: entities
title: LED-light
entities:
cards:
- type: entities
entities:
- type: gauge
title: Sauna Temp
min: 10
max: 100
theme: default
severity:
green: 0
yellow: 30
red: 50
dubbfredda
(Fredrik Jacobsson)
November 14, 2022, 12:15pm
15
Okay, thanks.
That made some changes…
But unfortunately can I still not edit the UI dashboard, receive following message
I only restarted the HA, is that enough?
Or do I need to restart the PC as well
HasQT
(Has)
November 14, 2022, 12:17pm
16
you can’t edit yaml dashboards in the ui.
you can have a UI main dashboard and yaml extra dashboards, only the UI one will be ui editable
dubbfredda
(Fredrik Jacobsson)
November 14, 2022, 12:23pm
17
I see, I hade the wrong dashboard selected when I tried
One other thing.
I can now see my extra dashboard in the sidebar, as I configured.
But I can still see my old dashboard in the header.
How can I remove this headers and add my new extra dashboard to the header?
HasQT
(Has)
November 14, 2022, 12:26pm
18
Click the pencil on the view(not home, it will be on test in my image) and then delete view.
the 3 dots in the top right next to DONE and the ? will let you view the raw config… which is yaml…
dubbfredda
(Fredrik Jacobsson)
November 14, 2022, 12:39pm
19
Okay, good now I managed to delete the old headings.
But how do I add my new yaml dashboard to the headings?
The ones I have in the sidebar
One other thing.
Before when I have made a changes to my yaml dashboard I just select refresh and then the new changes will be reloaded but now I can see that the refresh option is not available any more.
Is there any other way to load the yaml changes or do I need to restart the HA?
dubbfredda
(Fredrik Jacobsson)
November 14, 2022, 12:43pm
20
I got it, just select the yaml dashboard then the refresh option is there…
