Problem editing dashboard
I hope someone can help!
I have a fairly complex dashboard made using a Picture Elements card. It consists of about 2000 lines of yaml. I made a change to this today and was able to save the change without issue. Everything seemed okay.
On trying to make a second change I find that the Save button on the Picture Elements Card Configuration panel is just a spinning circle - suggesting that the code contains an error. So I have cancelled the change.
If I go to any dashboard (or even make a new one) then, if I make any change, the save button is just the spinning circle. I can’t save any changes.
Can anyone suggest what could be wrong?
EDIT: I tried deleting the dashboard made from the Picture Elements card and this didn’t help.
It was a browser issue. CTRL+F5 cleared the cash and fixed the issue.
Thanks - this solution was quite helpful today!
I’m having the same problem and CTRL+F5 doesn’t fix the problem. I also tried to clean the cache without success. Reboots also don’t work. Any idea of what else can I try? I can’t edit or add cards…
… which may be easily lost since you are keep using storage mode instead of yaml.
Happened to me today, control-F5 fixed it.
Super helpful solution, CTRL-F5 worked for me as well… saved me from reinstalling a backup copy as I was getting frustrated. Thanks!
