I just bought an ESP32-S2 mini from aliexpress (here), and I’m trying to set it up in order to make an movement detector (with a LD2410C).
I am far from the end of this mini project because I have issues to put esphome on my ESP-S mini…
I tried to use a basic YAML code from ESPHOME via HA. I had a lot of trouble to send the code on the ESP. Not working with ESPFLASHER, not working with ESPHOME web, … sometimes it works with HA if I plug the ESP directly on the HA hardware or with Adafruit…
Anyway, a lot of trouble… BUT now I might have a method to televerse the bin code.
My new problem is that teh ESP won’t connect to wifi.
The only code that is working (sometimes…) is the following
esphome:
friendly_name: test
esp32:
board: esp32-s2-saola-1
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "ehn0o/pfEbqjq0/xzq53bWc/UiQTbwkRS7OZwUMbMK0="
ota:
- platform: esphome
password: "fb8d6aaa59d6efce8e1961c7c15812b9"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Test Fallback Hotspot"
password: "MqU11tb05K22"
captive_portal:
I tried to put the following one, without success…
esphome:
friendly_name: capteur
esp32:
framework:
type: arduino
# Enable logging
logger:
api:
encryption:
ota:
- platform: esphome
wifi:
ap:
uart:
tx_pin: GPIO18
rx_pin: GPIO33
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2410:
binary_sensor:
- platform: ld2410
has_target:
has_moving_target:
has_still_target:
name: "Cible Immobile"
out_pin_presence_status:
name: "état broche présence"
- platform: gpio
pin: 15
name: "broche gpio présence"
device_class: presence
- platform: ld2410
light:
moving_distance:
name: "Distance Déplacement"
still_distance:
name: "Distance Immobile"
moving_energy:
still_energy:
name: "Énergie Immobile"
detection_distance:
name: "Distance de détection"
g0:
move_energy:
name: "g0 Énergie Mobile"
still_energy:
name: "g0 Énergie Immobile"
g1:
move_energy:
name: "g1 Énergie M"
still_energy:
name: "g1 Énergie I"
g2:
move_energy:
name: "g2 Énergie M"
still_energy:
name: "g2 Énergie I"
g3:
move_energy:
name: "g3 Énergie M"
still_energy:
name: "g3 Énergie I"
g4:
move_energy:
name: "g4 Énergie M"
still_energy:
name: "g4 Énergie I"
g5:
move_energy:
name: "g5 Énergie M"
still_energy:
name: "g5 Énergie I"
g6:
move_energy:
name: "g6 Énergie M"
still_energy:
name: "g6 Énergie I"
g7:
move_energy:
name: "g7 Énergie M"
still_energy:
name: "g7 Énergie I"
g8:
move_energy:
name: "g8 Énergie M"
still_energy:
name: "g8 Énergie I"
- platform: wifi_signal
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
update_interval: 60s
unit_of_measurement: "%"
entity_category: "diagnostic"
switch:
- platform: ld2410
engineering_mode:
name: "mode ingénierie"
bluetooth:
name: "contrôle bluetooth"
number:
- platform: ld2410
timeout:
light_threshold:
max_move_distance_gate:
name: "distance déplacement maximal"
max_still_distance_gate:
name: "distance Immobile maximal"
g0:
move_threshold:
name: "g0 seuil Énergie M"
still_threshold:
name: "g0 seuil I"
g1:
move_threshold:
name: "g1 seuil I"
still_threshold:
g2:
move_threshold:
name: "g2 seuil M"
still_threshold:
name: "g2 seuil I"
g3:
move_threshold:
name: "g3 seuil M"
still_threshold:
name: "g3 seuil I"
g4:
move_threshold:
name: "g4 seuil M"
still_threshold:
name: "g4 seuil I"
g5:
move_threshold:
name: "g5 seuil M"
still_threshold:
name: "g5 seuil I"
g6:
move_threshold:
name: "g6 seuil M"
still_threshold:
name: "g6 seuil I"
g7:
move_threshold:
name: "g7 seuil M"
still_threshold:
name: "g7 seuil I"
g8:
move_threshold:
name: "g8 seuil M"
still_threshold:
name: "g8 seuil I"
text_sensor:
- platform: ld2410
version:
name: "version du micrologiciel"
mac_address:
select:
- platform: ld2410
distance_resolution:
name: "résolution de distance"
light_function:
name: "fonction de lumière"
out_pin_level:
name: "niveau de broche de sortie"
button:
- platform: restart
icon: mdi:power-cycle
- platform: ld2410
restart:
query_params:
name: "paramètres de requête"
Does anyone have any idea to understant this shit? Did I make any mistake n my code?
Thank you for your help…
