I have a Ubuntu Server VM running on my ESXi box for Home-Assistent (hass.io). And it has worked pretty well, until now. I am not able to update Home-Assistant due to low disc capasity. Since this is an VM i have changed the disc spance for the VM from 10GB to 24GB. But now I need to expand the partition, witch I have some problems with.
I have tried to follow this guide, but are stuck on “Extend your Logical Volume with the new partition” or maybe before
this is what I have done:
Summary
# flemmingss@Home-Assistant:~$ ls /sys/class/scsi_host/
# host0 host11 host14 host17 host2 host22 host25 host28 host30 host4 host7
# host1 host12 host15 host18 host20 host23 host26 host29 host31 host5 host8
# host10 host13 host16 host19 host21 host24 host27 host3 host32 host6 host9
# flemmingss@Home-Assistant:~$ fdisk -l
# fdisk: cannot open /dev/sda: Permission denied
# fdisk: cannot open /dev/mapper/Home--Assistant--vg-root: Permission denied
# fdisk: cannot open /dev/mapper/Home--Assistant--vg-swap_1: Permission denied
# flemmingss@Home-Assistant:~$ sudo fdisk -l
# [sudo] password for flemmingss:
# Disk /dev/sda: 24 GiB, 25769803776 bytes, 50331648 sectors
# Units: sectors of 1 * 512 = 512 bytes
# Sector size (logical/physical): 512 bytes / 512 bytes
# I/O size (minimum/optimal): 512 bytes / 512 bytes
# Disklabel type: dos
# Disk identifier: 0xfce72dba
# Device Boot Start End Sectors Size Id Type
# /dev/sda1 * 2048 999423 997376 487M 83 Linux
# /dev/sda2 1001470 20969471 19968002 9.5G 5 Extended
# /dev/sda5 1001472 20969471 19968000 9.5G 8e Linux LVM
# Disk /dev/mapper/Home--Assistant--vg-root: 8.8 GiB, 9395240960 bytes, 18350080 sectors
# Disk /dev/mapper/Home--Assistant--vg-swap_1: 764 MiB, 801112064 bytes, 1564672 sectors
# flemmingss@Home-Assistant:~$ fdisk /dev/sda
# Welcome to fdisk (util-linux 2.27.1).
# Changes will remain in memory only, until you decide to write them.
# Be careful before using the write command.
# flemmingss@Home-Assistant:~$ sudo fdisk /dev/sda
# Command (m for help): n
# Partition type
# p primary (1 primary, 1 extended, 2 free)
# l logical (numbered from 5)
# Select (default p): p
# Partition number (3,4, default 3): 3
# First sector (999424-50331647, default 999424):
# Last sector, +sectors or +size{K,M,G,T,P} (999424-1001469, default 1001469):
# Created a new partition 3 of type 'Linux' and of size 1023 KiB.
# Command (m for help): t
# Partition number (1-3,5, default 5): 3
# Partition type (type L to list all types): 8e
# Changed type of partition 'Linux' to 'Linux LVM'.
# Command (m for help): w
# The partition table has been altered.
# Calling ioctl() to re-read partition table.
# Re-reading the partition table failed.: Device or resource busy
# The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8).
# ***REBOOT****
And this is what happen when I try to extend the volume:
flemmingss@Home-Assistant:~$ sudo vgextend Home-Assistant-vg /dev/sda3
Device /dev/sda3 not found (or ignored by filtering).
Unable to add physical volume '/dev/sda3' to volume group 'Home-Assistant-vg'.
Here are my current status:
fdisk -l
Disklabel type: dos
/dev/sda3 999424 1001469 2046 1023K 8e Linux LVM
Partition table entries are not in disk order.
pvscan
flemmingss@Home-Assistant:~$ sudo pvscan
PV /dev/sda5 VG Home-Assistant-vg lvm2 [9.52 GiB / 24.00 MiB free]
Total: 1 [9.52 GiB] / in use: 1 [9.52 GiB] / in no VG: 0 [0 ]
vgdisplay
flemmingss@Home-Assistant:~$ sudo vgdisplay
--- Volume group ---
VG Name Home-Assistant-vg
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 3
VG Access read/write
VG Status resizable
MAX LV 0
Cur LV 2
Open LV 2
Max PV 0
Cur PV 1
Act PV 1
VG Size 9.52 GiB
PE Size 4.00 MiB
Total PE 2437
Alloc PE / Size 2431 / 9.50 GiB
Free PE / Size 6 / 24.00 MiB
VG UUID 0wPc92-CBZG-mYBJ-vIpk-JYrO-uyij-c53LNq
lsblk
flemmingss@Home-Assistant:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 24G 0 disk
├─sda1 8:1 0 487M 0 part /boot
├─sda2 8:2 0 1K 0 part
├─sda3 8:3 0 1023K 0 part
└─sda5 8:5 0 9.5G 0 part
├─Home--Assistant--vg-root 252:0 0 8.8G 0 lvm /
└─Home--Assistant--vg-swap_1 252:1 0 764M 0 lvm [SWAP]
sr0 11:0 1 1024M 0 rom
So, do anyone have a solution for me?
I can say I am not a linux person, so in detail please.
