Hi all,
I have Home Assistant OS 6.1 up and running as a VM, running on Proxmox. Need USB passthrough for Conbee II to the HAOS VM, but its not working.
Actions taken
- USB passthrough to Home Assistant OS VM is done via Device ID
- Conbee II is visible in Supervisor - Hardware
- Reseted Conbee USB dongle on a Win 10 machine
- Added an USB extention cable to the dongle
Issues
The Phoscon web app is not available on http://IP_TO_HAOS/pwa/login.html (should it be installed on HAOS VM?)
Adding deconz as an integration it asks for an IP address. Typing the HAOS IP generates a API Key error (which kind of makes sense if its not responding and I cannot link it)
Using Supervisor Official Add-ons for Deconz, installation fails with
Can't install homeassistant/amd64-addon-deconz:6.9.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=6.9.0&fromImage=homeassistant%2Famd64-addon-deconz: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
Any suggestions?
Thanks!
Setup
- Proxmox VE 7.01
- Home Assistant OS 6.1
- Home Assistant Core: 2021.7.4
- Deconz Conbee II firmware: 2.12.03 / 7/12/2021
