Problem getting my iPhone to login and connect to server
Last couple of days my iPhone will not connect to the server correctly. (my home computer and iPad are fine). The home assistant device is fully upto date so is server.
The HA server has only 9% memory used.
This is the message I am getting :-
any ideas please.
thanks
I would start here: Troubleshooting | Home Assistant Companion Docs
Edit: and a potential solution here: WebSocket error in iOS app - #5 by keithellis. Reboot your server (not just HA)
Thanks, nothing obvious there.
I have been using everything for over a year without problem, but this just started couple days ago.
The “no space left on device” error seems to be a clue and I’m guessing that it is your iOS device (not HA - but I would check there too). I don’t use iOS so I don’t know how to see space used or clear space on it.
Have you tried rebooting your phone and the HA server?
Thanks, not yet but i will reboot both later this evening.
my iPhone has loads of free space 43gb + so that should not be an issue :slight_smile:
I will see what happens after reboot.
well rebooting appears to have done the trick.
thanks for help
