Problem Getting Schedule Card Installed on HA Core
I’ve been having a problem getting HACS, Scheduler Card to properly install and function.
I have Home Assistant (HA) Core, version 2023.3.6 running with Frontend 20230309.1 on a Raspberry Pi 4, 8 GB running Raspberry Pi OS 64, version 11 (bullseye). I have updated Python to version 11.2 without incident and have HA running fine as a service. Both HACS and Scheduler Component seemed to have loaded without incident and HACS, Integrations shows both a HACS and Scheduler Component card installed without complaint.
Clicking on HACS on the left side of the screen shows the message “Not loaded in Lovelace. You have 1 Lovelace elements that are not loaded properly in Lovelace.” Moving to Frontend shows Scheduler Card bordered in red with the top line message of “Not loaded”. When I click on Scheduler Card I get a display of the Scheduler Card READ.MD. Also in Frontend is the Daily Schedule Card which is not bordered in red and looks normal. When I click on it I get a documentation page. When I go to Integrations and click on Scheduler Component I get a display of the Scheduler Component READ.MD.
I have looked at everything I could find on the web and have so far been unsuccessful.
Obviously something is broken here. Two questions:
  1. I would like to remove Daily Schedule Card from HACS, Frontend. I can’t. I worry it will conflict with Scheduler Card.
  2. I would like to properly install and use Scheduler Card in HACS, Frontend.
Please help anyone.
