I had to use their experimental zwave binding with security to get my yale lock working.
All of my zwave devices are currently connected to a Z-Stick Gen 5 (from when I was using openhab)
I have the zwave security key from open hab it is in "XX YY ZZ… " format
my config :
zwave:
usb_path: /dev/ttyACM0
*I tried adding to above and I get the same message with or without it
network_key: (changed to above, just added 0x before each and a “,” after so it is "0xXX, 0xYY, 0xZZ… " format
Problem
from what I can tell I can not connect to the zwave stick the config test says:
homeassistant:
- extra keys not allowed @ data[‘zwave’]
- auth_providers: [source /home/homeassistant/.homeassistant/configuration.yaml:2]
Is this error because I need to “Factory reset the stick” and relearn all of my devices or is it because I don’t have the the USB recognized correctly (or something else)?
In Home assistant you dont use the stick to pair with the devices, you do it from the zwave configuration panel.
To be safe you should unpair all your devices from the stick, then factory resetting it would be a good idea just to be sure. Then pair all your devices through the HA zwave configuration panel. For your lock you have the option of using secure pairing in HA, just make sure you set up a network key first. EDIT, after reading your post properly I see you have set up the key already.
Also It would help if you edit your post to correctly format your zwave config code as per the blue banner at the top of the page.
I did confirm that the path is /dev/ttyACM0. I get the same results whether I use device_config or not.
Do you think the existing configuration is causing the communication issue/error? My theory was that I shouldn’t have to F/R my my usb stick. I’m kinda testing both right now, so I’d prefer not to as it is working (mostly) with openhab still.
2018-09-09 21:32:42 ERROR (MainThread) [homeassistant.config] Invalid config for [homeassistant]: [zwave] is an invalid option for [homeassistant]. Check: homeassistant->zwave. (See /home/homeassistant/.homeassistant/configuration.yaml, line 1).
the config path is necessary if your install put the config files & options.xml file in a non standard location but it doesn’t hurt to specify the path either way. You also need to put your network key in your options.xml file too.
Not sure if it matters, but it looks like I am using python 3.5. I did the hassbian install.
also /srv/homeassistant/lib/python3.5/site-packages/python_openzwave does not exist. I was under the assumption that openzwave would be installed when I enabled the component.
It doesn’t matter which python version (as long as it’s over 3.4.something). it is likely listed in the same path as above but change the …/python3.6/… to …/python3.5/…
If not then just do a search for the ozw_config directory. you should see a bunch of subdirectories there that have manufacturer names and also an options.xml file. The files might be getting installed somewhere else now. That was the path that was default for the HA virtual environment when I installed my zwave in hassbian a year ago (I’ve moved on to using a NUC and installing in docker).
And yes, those files should be installed as soon as you successfully include zwave in your config. If they never got installed anywhere at all then there may be some other issue going on.
Sorry for the delay- All of my existing devices are now recognized by Home Assistant. However not all are functioning correctly (or at all). Some of the devices have names from openhab still. I’ll probably end up resetting the zwave stick and re-learning all of the devices again. Hopefully that will get things going 100%.
