Problem Home Assistant Supervised Docker exited
I try to install supervised home assistant on docker with this command but the core appears “exit” after a few minutes, why?
curl -sL https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh | bash -s – -m raspberrypi4
results :
homeassistant/raspberrypi4-homeassistant:2021.3.2 “/init” About a minute ago Exited (0) About a minute ago
thank you for your help !
Hi @hassioRX , were you ever able to resolve this?
