Im trying to import distance from a hc-sr04 (ultrasonic sensor) with a python script by using command_line platform but i only get “Command failed: python3 /home/pi/rpi-examples/HC-SR04/python/distance.py” in my logs… the script works if i run it in the terminal.
this is from my config file.
- platform: command_line
scan_interval: 5
command: “python3 /home/pi/rpi-examples/HC- SR04/python/distance.py”
unit_of_measurement: “C”
and this is from my python script
import RPi.GPIO as GPIO
import time
import signal
import sys
# use Raspberry Pi board pin numbers
GPIO.setmode(GPIO.BCM)
# set GPIO Pins
pinTrigger = 18
pinEcho = 24
def close(signal, frame):
print("\nTurning off ultrasonic distance detection...\n")
GPIO.cleanup()
sys.exit(0)
signal.signal(signal.SIGINT, close)
# set GPIO input and output channels
GPIO.setup(pinTrigger, GPIO.OUT)
GPIO.setup(pinEcho, GPIO.IN)
while True:
# set Trigger to HIGH
GPIO.output(pinTrigger, True)
# set Trigger after 0.01ms to LOW
time.sleep(0.00001)
GPIO.output(pinTrigger, False)
startTime = time.time()
stopTime = time.time()
# save start time
while 0 == GPIO.input(pinEcho):
# save time of arrival
while 1 == GPIO.input(pinEcho):
# time difference between start and arrival
TimeElapsed = stopTime - startTime
# multiply with the sonic speed (34300 cm/s)
# and divide by 2, because there and back
distance = (TimeElapsed * 34300) / 2
print ("%.1f " % distance)
time.sleep(1)
GPIO.cleanup()
quit()
maby im thinking this all wrong? shouldnt ha be able to extract the printed value? im noob at both ha and python
if i do this it works like a charm
print(“35”)
