This runs every 60 seconds, not each hour. The calculation is instantaneous, so it doesn’t run for 2 hours a day. Every 60 seconds, it looks that the endpoint and outputs the result.
Yes, you are right. Every 60 seconds. But it doesn’t change the statement. After each hour the reported timeframe is shifted by 1h and that means the 1-2-4 reported cheapest hours can shift each hour. I think they should be calculated once per day for the day. Because you usually want to switch on devices a certain timeframe (namely 1, 2 or 4h) per day and want to be sure they run that amount and not longer or shorter.
The minimum is calculated. If it shifts, it’s still the minimum and the index shifts with it. The time doesn’t change neither does the value.
Anyways, I reviewed whats going on here and I see ways to optimize this so you can get your timeframe and the lowest x hours as sensors
Put this in your sensor section
- platform: rest
resource: https://api.awattar.de/v1/marketdata
json_attributes:
- data
scan_interval: 60
value_template: >
{% set start = (today_at().timestamp() * 1000) | int %}
{% set end = ((today_at() + timedelta(days=1)).timestamp() * 1000) | int %}
{% set values_today = value_json.data | selectattr('start_timestamp', '>=', start) | selectattr('end_timestamp', '<=', end) | list %}
{% set min_today = values_today | sort(attribute='marketprice') | first %}
{% set i = values_today.index(min_today) %}
{% set hours = 4 %}
{% set search = hours - 1 %}
{% set s = i - search if i - search >= 0 else 0 %}
{% set s = value_json.data.index(values_today[s]) %}
{% set e = i + search if i + search < values_today | length else values_today | length - 1 %}
{% set e = value_json.data.index(values_today[e]) %}
{{ s }},{{ e }},{{ value_json.data[s].start_timestamp | multiply(0.001) | timestamp_local }}
Put this in configuration.yaml
template:
- trigger:
- platform: state
entity_id: sensor.awattar
variables:
value: >
{{ trigger.to_state.state if trigger.to_state.state not in ['unavailable', 'unknown'] else '0,0,0' }}
time_span: >
{% set set s, e = value | split(',')[:2] | map('int') %}
{% set hours = 4 %}
{% set ns = namespace(windows=[]) %}
{% for span in range(e - s) %}
{% set roll = (e - s) - span %}
{% set sub = namespace(window=[]) %}
{% for i in range(roll) %}
{% set total = data[s+i:s+span+i+1] | selectattr('marketprice', 'defined') | map(attribute='marketprice') | sum %}
{% set sub.window = sub.window + [ {'timestamp':data[s+i].start_timestamp//1000, 'total':total} ] %}
{% endfor %}
{% set item = sub.window | sort(attribute='total') | first %}
{% set ns.windows = ns.windows + [ (span+1, item) ] %}
{% endfor %}
{{ dict.from_keys(ns.windows) }}
- name: Awatter One Hour Min
state: "{{ time_span.1.total }}"
- name: Awatter One Hour Timestamp
state: "{{ time_span.1.timestamp | timestamp_local | as_datetime }}"
device_class: timestamp
- name: Awatter Two Hour Min
state: "{{ time_span.2.total }}"
- name: Awatter Two Hour Timestamp
state: "{{ time_span.2.timestamp | timestamp_local | as_datetime }}"
- name: Awatter Three Hour Min
state: "{{ time_span.3.total }}"
- name: Awatter Three Hour Timestamp
state: "{{ time_span.3.timestamp | timestamp_local | as_datetime }}"
state: "{{ time_span.4.total }}"
state: "{{ time_span.4.timestamp | timestamp_local | as_datetime }}"
Might have some issues, lemme know if it does
Thanks Petro.
indeed there seem to be some small issues. First, there are in line 9 2x “set”. I removed one. Still there is a message that some block end is missing. It seems to be around that line as well…
Logger: homeassistant.config
Source: config.py:929
First occurred: 19:51:31 (1 occurrences)
Last logged: 19:51:31
Invalid config for [template]: invalid template (TemplateSyntaxError: expected token 'end of statement block', got '[') for dictionary value @ data['trigger'][0]['variables']['time_span']. Got "{% set s, e = value | split(',')[:2] | map('int') %} {% set hours = 4 %} {% set ns = namespace(windows=[]) %} {% for span in range(e - s) %} {% set roll = (e - s) - span %} {% set sub = namespace(window=[]) %} {% for i in range(roll) %} {% set total = data[s+i:s+span+i+1] | selectattr('marketprice', 'defined') | map(attribute='marketprice') | sum %} {% set sub.window = sub.window + [ {'timestamp':data[s+i].start_timestamp//1000, 'total':total} ] %} {% endfor %} {% set item = sub.window | so.... (See /config/configuration.yaml, line 26).
Imagine a list of prices, let’s say at 00:00 that go straight down: 50,49,…,26 for the first 24 hours. Cheapest hour: At 23:00 with 26 ct.
Then, one later, at 1:00 the new call shifts the list. So it starts now with 49 and goes down to 25. The new cheapest hour is at 00:00 (next day) with 26 ct.
That means the first day will never “reach” the cheapest hour.
What you’re saying doesn’t make sense. If the values change, the new cheapest hour is found. If the values are static and shift one hour. The cheapest value will still be the cheapest value. If you’re simply trying to say “I don’t want it to find values from tomorrow” then just say that. Otherwise the shifting of values has no impact on the calculation as it searches for the smallest and reports the index.
I’m trying my best. That’s why I try to explain what I mean. No reason to get angry on me. For me, it makes sense. Just not including values from tomorrow is too short-sighted. I think it’s about viewing at a whole day from 0:00 until 23:59.
In general, I want to run - let’s say a heating rod - for the cheapest 2h a day. Or disable the heating pump during the 2 most expensive hours a day.
Right, I get that. But you keep focusing on the data shifting when that won’t impact the result because template searches for the minimum. If the minimum moves position in the list, it’ll still find that minimum.
Here’s it all fixed
Sensor that chops data at midnight.
- platform: rest
json_attributes:
- data
scan_interval: 60
value_template: >
{% set hours = 4 %}
Updates whenever the data changes.
template:
- trigger:
- platform: state
variables:
the_state: >
{% if trigger.to_state and trigger.to_state.state not in ['unknown', 'unavailable'] %}
{% set s, e = trigger.to_state.state.split(',') | map('int', none) | reject('none') %}
{{ {'s': s, 'e': e, 'data': trigger.to_state.attributes.data } }}
{'s': 0, 'e': 0, 'data': []}
time_span: >
{% set s, e, data = the_state.s, the_state.e, the_state.data %}
{% set hours = 4 %}
{% set ns = namespace(windows=[], out=[]) %}
{% set sub.window = sub.window + [ {'timestamp':(data[s+i].start_timestamp//1000) | timestamp_local, 'total':total} ] %}
{% endfor %}
{% endfor %}
{% set items = dict.from_keys(ns.windows) %}
{% for i in range(1, hours+1) %}
{% set ns.out = ns.out + [ (i, items[i]) if i in items else (i,{'timestamp': None, 'total': None}) ] %}
{% endfor %}
{{ dict.from_keys(ns.out) }}
state: "{{ time_span.1.total * 100/1000 * 1.20 }}"
state: "{{ time_span.1.timestamp | as_datetime }}"
state: "{{ time_span.2.total * 100/1000 * 1.20 }}"
state: "{{ time_span.2.timestamp | as_datetime }}"
state: "{{ time_span.3.total * 100/1000 * 1.20 }}"
state: "{{ time_span.3.timestamp | as_datetime }}"
state: "{{ time_span.4.total * 100/1000 * 1.20 }}"
state: "{{ time_span.4.timestamp | as_datetime }}"
Updates once at midnight for the day
template:
- trigger:
- platform: time
at: "00:00:01"
variables: &awatter_variables
the_state: >
{% set to_state = expand('sensor.awattar') | first %}
{% if to_state and to_state.state not in ['unknown', 'unavailable'] %}
{% set s, e = to_state.state.split(',') | map('int', none) | reject('none') %}
{{ {'s': s, 'e': e, 'data': to_state.attributes.data } }}
time_span: >
{% set hours = 4 %}
{% endfor %}
{% endfor %}
{% endfor %}
- platform: homeassistant
event: start
variables: *awatter_variables
Keep in mind, the updates once at midnight will update on restart as well. It will not update on template reload. So you have to wait until midnight to see the state or restart the system.
Thanks for the help. In the meantime I don’t have any glue anymore on what the algorithm does ;-). Runs now and delivers data.
One slight issue: When updated during the day (restart) the api being called without startdate only returns values from now on. That means it show the cheapest hour for today in 13 hours, but it was 6 hours ago (HOURLY Preis Chart - mehr Wind und Sonne, mehr sparen!).
Is it possible to pass today, 00:00 as epochseconds to the script? Syntax is
https://api.awattar.at/v1/marketdata?start=<startdatetime in epochseconds>
I think I have it.
URL call needs to be (instead of resource):
resource_template: 'https://api.awattar.at/v1/marketdata\start={{today_at().timestamp() * 1000 }}'
yep
To be honest, I switched back to the original solution. That is maybe less efficient, but for me better to understand and to extend.
I extended that now with:
- API is called with the current day at 0:00 to always get the values for the current day as a full.
- A new sensor is added for the average price of the day
- A new sensor is added for the current price (This is why it still runs every 60 sec)
- New sensors for the expensive hours a day
- Unfortuntately not solved: Median price of the day
Attention: I am using the Austrian API (extension .at) and Austrian VAT (20% insteady of 19% in DE)
Here is my current sensor.yaml
#aWattar Strompreise
- platform: rest
resource_template: 'https://api.awattar.at/v1/marketdata?start={{today_at().timestamp() * 1000 }}'
json_attributes:
- data
scan_interval: 60
value_template: "{{ (value_json.data[0]) }}"
sensors:
awattar_count:
friendly_name: "Count of available prices"
value_template: >-
{% set count = state_attr('sensor.awattar', 'data') | list | length %}
{{ count }}
awattar_average:
friendly_name: "Average of available prices"
value_template: >-
{%- set awattar_list = state_attr('sensor.awattar', 'data') | map(attribute='marketprice') | list %}
{{ awattar_list | average | float * 100/1000 * 1.20 | round(2) }}
awattar_current:
friendly_name: "aWattar current price"
value_template: >-
{% set h = now().hour | int %}
{{ awattar_list[h] | float * 100/1000 * 1.20 | round(2) }}
awattar_values:
friendly_name: "All aWattar values"
value_template: >-
{%- set awattar_all_list = state_attr('sensor.awattar', 'data') | map(attribute='marketprice') | list %}
{%- set values_all = namespace(all=[]) %}
{% for i in range(awattar_all_list | length) %}
{%- set v = (awattar_all_list[i] | float * 100/1000 * 1.20) | round(2) %}
{%- set values_all.all = values_all.all + [ v ] %}
{%- endfor %}
{{ values_all.all }}
awattar_one_hour_min_index:
friendly_name: "aWattar one hour minimum value index in available dataset"
value_template: >-
{%- set values = namespace(min=[]) %}
{% for i in range(awattar_list | length) %}
{%- set v = (awattar_list[i] | float * 100/1000 * 1.20) | round(2) %}
{%- set values.min = values.min + [ v ] %}
{%- endfor %}
{{ values.min.index(values.min | min) }}
awattar_one_hour_min_value:
friendly_name: "aWattar one hour minimum value in available dataset"
value_template: >-
{%- endfor %}
{{ values.min | min }}
awattar_one_hour_min_timestamp:
friendly_name: "aWattar one hour minimum value timestamp in available dataset"
value_template: >-
{% set index = states('sensor.awattar_one_hour_min_index') | int %}
{% set table = state_attr('sensor.awattar', 'data') %}
{{ ( table[index].start_timestamp | int / 1000 ) | timestamp_local}}
awattar_two_hour_min_index:
friendly_name: "aWattar two hour minimum start index"
value_template: >-
{% if i + 1 < awattar_list | length %}
{%- set v = (awattar_list[i] | float * 100/1000 * 1.20 ) | round(2) %}
{%- set next = (awattar_list[i+1] | float * 100/1000 * 1.20 ) | round(2) %}
{%- set values.min = values.min + [ v + next ] %}
{%- endfor %}
awattar_two_hour_min_timestamp:
friendly_name: "aWattar two hour minimum value start timestamp in available dataset"
value_template: >-
{% set index = states('sensor.awattar_two_hour_min_index') | int %}
awattar_four_hour_min_index:
friendly_name: "aWattar four hour minimum start index"
value_template: >-
{% if i + 3 < awattar_list | length %}
{%- set v1 = (awattar_list[i] | float * 100/1000 * 1.20 ) | round(2) %}
{%- set v2 = (awattar_list[i+1] | float * 100/1000 * 1.20 ) | round(2) %}
{%- set v3 = (awattar_list[i+2] | float * 100/1000 * 1.20 ) | round(2) %}
{%- set v4 = (awattar_list[i+3] | float * 100/1000 * 1.20 ) | round(2) %}
{%- set values.min = values.min + [ v1 + v2 + v3 + v4 ] %}
{%- endfor %}
awattar_four_hour_min_timestamp:
friendly_name: "aWattar four hour minimum value start timestamp in available dataset"
value_template: >-
{% set index = states('sensor.awattar_four_hour_min_index') | int %}
awattar_one_hour_max_index:
friendly_name: "aWattar one hour max value index in available dataset"
value_template: >-
{%- set values = namespace(max=[]) %}
{%- set values.max = values.max + [ v ] %}
{%- endfor %}
{{ values.max.index(values.max | max) }}
awattar_one_hour_max_value:
friendly_name: "aWattar one hour max value in available dataset"
value_template: >-
{%- endfor %}
{{ values.max | max }}
awattar_one_hour_max_timestamp:
friendly_name: "aWattar one hour max value timestamp in available dataset"
value_template: >-
{% set index = states('sensor.awattar_one_hour_max_index') | int %}
awattar_two_hour_max_index:
friendly_name: "aWattar two hour max start index"
value_template: >-
{%- set values.max = values.max + [ v + next ] %}
{%- endfor %}
awattar_two_hour_max_timestamp:
friendly_name: "aWattar two hour max value start timestamp in available dataset"
value_template: >-
{% set index = states('sensor.awattar_two_hour_max_index') | int %}
Just keep in mind the original solution doesn’t find the lowest. It finds the lowest point and then chooses the 4 after. What I do is find the lowest 4 in a row, 3 in a row, 2 in a row. EDIT: Well maybe it does now that I look at it.
EDIT2: I forgot to add the conversions, so I added it to that post
EDIT3: FYI your ‘count’, ‘average’, and ‘current’ sensors and all that remain unchanged if that’s what you were unsure about. The updates only affect the selection and rolling.
Also, fyi your rounds(2) are doing nothing. You need to round the whole result, not just 1.20
anyways, here’s median
{% set values = state_attr('sensor.awattar', 'data')| map(attribute='marketprice') | list | sort %}
{% set total = values | length %}
{% set ns = namespace(half= total // 2, divisor = 1) %}
{% if not (total - ns.half * 2) % 2 %}
{% set ns.half = ns.half - 1 %}
{% set ns.divisor = 2 %}
{{ (values[ns.half:-ns.half] | sum / ns.divisor * 0.1 * 1.20) | round(2) }}
Hey there, I need to chime in quickly - love your templates and am now trying to get only the price for the current hour, so HA can use it for the energy dashboard.
Well, I fail miserably at it … could you help me?!
Includes now the additions (Median, round correction) by Petro (thanks, one more time) and current price (by me) as well as the end timestamps that may be needed for automations to be able to trigger the end times for turning devices off.
- platform: rest
json_attributes:
- data
scan_interval: 60
sensors:
awattar_count:
value_template: >-
{{ count }}
awattar_average:
value_template: >-
{{ (awattar_list | average | float * 100/1000 * 1.20) | round(2) }}
awattar_current:
friendly_name: "Current price"
value_template: >-
{{ (awattar_list[h] | float * 100/1000 * 1.20) | round(2) }}
awattar_median:
friendly_name: "Median of available prices"
value_template: >-
awattar_values:
value_template: >-
{%- endfor %}
friendly_name: "One hour minimum index in available dataset"
value_template: >-
{%- endfor %}
friendly_name: "One hour minimum value in available dataset"
value_template: >-
{%- endfor %}
awattar_one_hour_min_starttimestamp:
friendly_name: "One hour minimum start timestamp in available dataset"
value_template: >-
awattar_one_hour_min_endtimestamp:
friendly_name: "One hour min end timestamp in available dataset"
value_template: >-
{{ (as_timestamp(states('sensor.awattar_one_hour_min_starttimestamp')) + 1 * 3600) | timestamp_local }}
friendly_name: "Two hour minimum start index"
value_template: >-
{%- endfor %}
awattar_two_hour_min_starttimestamp:
friendly_name: "Two hour minimum start timestamp in available dataset"
value_template: >-
awattar_two_hour_min_endtimestamp:
friendly_name: "Two hour min end timestamp in available dataset"
value_template: >-
{{ (as_timestamp(states('sensor.awattar_two_hour_min_starttimestamp')) + 2 * 3600) | timestamp_local }}
friendly_name: "Four hour minimum start index"
value_template: >-
{%- endfor %}
awattar_four_hour_min_starttimestamp:
friendly_name: "Four hour minimum start timestamp in available dataset"
value_template: >-
awattar_four_hour_min_endtimestamp:
friendly_name: "Four hour min end timestamp in available dataset"
value_template: >-
{{ (as_timestamp(states('sensor.awattar_four_hour_min_starttimestamp')) + 4 * 3600) | timestamp_local }}
friendly_name: "One hour max index in available dataset"
value_template: >-
{%- endfor %}
friendly_name: "One hour max value in available dataset"
value_template: >-
{%- endfor %}
awattar_one_hour_max_starttimestamp:
friendly_name: "One hour max start timestamp in available dataset"
value_template: >-
awattar_one_hour_max_endtimestamp:
friendly_name: "One hour max end timestamp in available dataset"
value_template: >-
{{ (as_timestamp(states('sensor.awattar_one_hour_max_starttimestamp')) + 1 * 3600) | timestamp_local }}
friendly_name: "Two hour max start index"
value_template: >-
{%- endfor %}
awattar_two_hour_max_starttimestamp:
friendly_name: "Two hour max start timestamp in available dataset"
value_template: >-
awattar_two_hour_max_endtimestamp:
friendly_name: "Two hour max end timestamp in available dataset"
value_template: >-
{{ (as_timestamp(states('sensor.awattar_two_hour_max_starttimestamp')) + 2 * 3600) | timestamp_local }}
Great!
two questions:
I kind of would like to use:
https://api.awattar.at/v1/marketdata?start={{(today_at().timestamp() * 1000 ) | round(0, default=“not available”)}}&end={{(((today_at().timestamp()) + 172800) * 1000) | round(0, default=“not available”) }}
so it gives me all values (as soon as available) for the next day also.
This seems to work fine, except for the awattar_values
sensor, which shows unknown
secondly, I assume when you multiply by 1.20
, this is because of taxes, right?! but doesn’t aWattar also add 3% for their profit?! at least that’s what it says here HOURLY - mehr Wind und Sonne, mehr sparen! when you scroll down to “Tarifübersicht” : “Energieverbrauchspreis EPEX Spot AT ® * 1.03 (3%) Cent/kWh netto”
Or is this already included in the values from the API call?!
Regarding 3%: I don’t think it’s included, but you can anyways only narrow the real price. There is also a basic charge per month and then network costs from your infrastructure provider.
Maybe it’s even better to keep the net price without VAT.
