Problem in building a JSON list of data
personally, i’d change your main sensor to out put the index of the 2 minimum. Then just simply grab the values in another template sensor.
  - platform: rest
    resource: https://api.awattar.de/v1/marketdata
    value_template: >
      {%- set awattar_list = value_json.data | map(attribute='marketprice') | list %}
      {%- set values = namespace(min=[]) %}
      {% for i in range(awattar_list | length) %}
        {% if i + 1 < awattar_list | length %}
          {%- set v = (awattar_list[i] | float * 100/1000 * 1.19 + 19.22) | round(2) %}
          {%- set next = (awattar_list[i+1] | float * 100/1000 * 1.19 + 19.22) | round(2) %}
          {%- set values.min = values.min + [ v + next ] %}
      {%- endfor %}
      {{ values.min.index(values.min | min)  }}
    json_attributes:
      - data
    scan_interval: 60
    sensors:
      lowest_awattar:
        friendly_name: "Lowest awattar"
        value_template: >-
          {% set index = states('sensor.awattar_table') | int %}
          {% set table = state_attr('sensor.awattar', 'data') %}
          {{ (table[index].marketprice | float * 100/1000 * 1.19 + 19.22) | round(2) }}
      lowest_awattar_timestamp:
        friendly_name: "Lowest awattar timestamp"
        device_class: timestamp
        value_template: >-
          {{ table[index].start_timestamp | int / 1000 }}
      lowest_awattar_2:
        friendly_name: "Second lowest awattar"
        value_template: >-
          {{ (table[index+1].marketprice | float * 100/1000 * 1.19 + 19.22) | round(2) }}
      lowest_awattar_timestamp_2:
        friendly_name: "Second lowest awattar timestamp"
        value_template: >-
          {{ table[index+1].start_timestamp | int / 1000 }}
Breakdown:
Takes data (which is a list of dictionaries) and filters it to a list marketprice values.
Creates an empty list that we can use to store values, it’s named values.min
Loop through your data, using i, where i is a indexer (position in the list)
check if we have an position in the list after the current position
get our current math value
get our next math value
add the 2 values together and add it to the list
end the if statement and the for loop
{%- endfor %}
Get the lowest par, then find it’s position in the list, output that position
The template sensors just use that position to output the data:
calculates the first item in the lowest pair (using the index)
calculates the first items timestamp in the lowest pair (using the index)
calculates the second item in the lowest pair (using the index)
calculates the second items timestamp in the lowest pair (using the index)
