Problem in configuration with duckdns
Hi to all, I have installed home assistant supervisor with docker on my raspberry pi 4 with the last raspberry so 32 bit.
It’s work fine but I have a integration problem with duckdns.
I have installed, configured and run add-on, the log it’s all ok.
When I put this string
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
In the end of configuration.yaml, after reboot I can’t access to home assistant in local and in remote.
I try many times but the results is ever the same.
I don’t understand what I wrong.
Thanks to any reply
After completing the installation you now have to access home assistant with https:// not http://.
Also in local network?
Yes.
You will also have to add a certificate exception in your web browser if navigating to the ip address as the security certificate is for the domain, not the ip address.
Thank you so much! It works good.
Now doesn’t work android app, I have changed http in https but only work on browser
Unfortunately I can’t help you there I use the iOS app.
If it works in a browser on your phone it should work in the app.
There is no way to “add an exception” in the Android app, afaik.
My workaround: Add a manual DNS entry in my local router pointing the FQDN to the local IP of HA.
Oh right. Yeah same for iOS. I just used the duckDNS address and relied on hairpinning in my router.
Or that, ofc.
I actually did the DNS workaround without knowing hairpinning was a thing, so I don’t actually know if my router supports it :wink:
Now I am watching to use remotely, I have home connection by sim
If your ISP uses CGNAT it will not work with DuckDNS.
Yes I know, now I watching to another solution, but for now only money solutions
I just created a guide to have a reverse proxy working with CGNAT
