Problem in lovelace graph card since last upgrade
I have the following code in configuration.yalm:
  - platform: mqtt
    state_topic: "Temperatura"
    unit_of_measurement: '°C'
And I only read in graph card: No state history found.
I have deleted home-assistant_V2.db, and restart, as advised in other forum posts, but the problem persists.
And the entity: This entity does not have a unique ID, therefore its settings cannot be managed from the UI.
Any idea???
No exclusion in recorder?
Hi, thanks for answering. I don’t have any exclusions in recorder.
I don’t have anything included either abaut recorder, but I didn’t before and it worked for me. I just included it, but it’s still the same.
All my configuration.yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
recorder:
  include:
    domains:
      - sensor
      - switch
sonoff:
  username: xxxxxxxxxxxxxxxxxxxxx
  password: xxxxxxxxxxxxxxxx
  scan_interval: 60
  grace_period: 600
  api_region: 'eu'
  - platform: mqtt
switch:
  - platform: mqtt
    state_topic: "Estado"
    command_topic: "Encender"
    payload_on: "ON"
    payload_off: "OFF"
Thank you!
I just checked that it appears on the mobile app, but not on the computer. What happens!!! :frowning:
Maybe Cache. Try to force refresh: CTRL + F5
