I have a Ubuntu server (Ubuntu 20.04.1 LTS) where I just successfully installed Home Assistant using the following method: supervised-installer
I’m now able to log in to my Home Assistant, do the initial configuration and go all around it. The problem is that each time I try to install an addon I get the error message: “Unknown error, see supervisor”. And when I go to “supervisor/system” I see this “Your installation is running in an unhealthy state” and the following warning on the logs: “21-01-02 23:13:12 WARNING (MainThread) [supervisor.jobs] ‘AddonManager.install’ blocked from execution, system is not healthy”.
The server machine was formatted and has a clean and updated version of Ubuntu and I have installed anything else than Home Assistant on it. I was expecting a fully functional Home Assistant Supervised where I could install my addons as usual.
Can anyone advise me how to proceed to have it working properly?
Thank you
