Problem installing with WiFi
about 10 months ago I had a good working Hassbian installation.
Becourse I moved, I had to shut it down for a while.
Now I try to install home assistant on the same RP on the same router with the same SD-card(s) but I can’t get WiFi to work with the same settings.
Nerwork wise nothing has changed till the connection with the fibercabele from outsite.
I can even do a (partly) install of hassbian on the same configuration.
the hassbian installation can be found with Fing and the new home assistant install can not
Anyone any idea what I can/should do ?
I did make a uuid for the rest I just copied and past
I have pretty much similar issue. Did you manage to solve it?
No
Nog connected through Cable
