Problem integrating DS18B20 with ESP32-C3 Super Mini and ESPHome 2025.3.2
Hi everyone,
I’m trying to integrate a DS18B20 temperature sensor into my Home Assistant setup using ESPHome (version 2025.3.2) on a Synology DS412+ (running in Docker). The sensor is connected to an ESP32-C3 Super Mini as follows:
  • Red → 3.3V
  • Black → GND
  • Yellow → GPIO4
My goal is to read the temperature via ESPHome and show it in Home Assistant.
Here’s my current YAML configuration:
esphome:
  friendly_name: ESP_Mini_1
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: arduino
logger:
api:
  encryption:
    key: "..."
ota:
  - platform: esphome
    password: "..."
wifi:
  ssid: "MyWiFi"
  password: "MyPassword"
  ap:
    ssid: "Esp-Mini-1 Fallback Hotspot"
    password: "..."
one_wire:
  pin: GPIO4
  - platform: dallas_temp
captive_portal:
No matter what I try, ESPHome keeps throwing this error:
Failed config
one_wire.unknown:
  'one_wire' requires a 'platform' key but it was not specified.
I’ve already tried:
  • Changing the sensor platform to dallas, dallas_temp, one_wire, etc.
  • Adding or removing the platform field under one_wire
  • Updating ESPHome
  • Testing different pins (GPIO1, GPIO4)
  • Checking wiring (which should be fine)
I’m a bit stuck and would really appreciate your help. Has anyone successfully integrated a DS18B20 with an ESP32-C3 recently using the new ESPHome version?
Thanks in advance!
use the docs:
you are missing the platform key just like the error message says
# Example configuration entry
one_wire:
  - platform: gpio
    pin: GPIO4
This was the Solution. Many Thanks for that.
