Problem integration zha
I try everything and I always have a problem with my Zigbee Zigate V1 keys.
When I add with the ZHA integration here is what I have.
Can you help me?
Merci
2021-11-23_11h26_36
if you have a Zigate, why is there an error from deconz ? Did you have a conbee first and did you not remove everything ?
I’ve never had and connected conbee to my HA. Weird that.
Maybe you selected “deconz” instead of “zigate” as radio type during ZHa config flow?
Check ZHA radio type configuration in Home Assistant configuration.yaml
I also do not think the latest ZiGate firmware is suppported yet(?) so maybe use older.
https://github.com/zigpy/zigpy-zigate
Okay but how can I do that?
I don’t see where to choose Deconz if I don’t have conbee keys. : /
