Problem mit HA und conbee2 am Raspi3
I have HA running on a Raspberry Pi 3.
Now I bought the CONBEE 2 stick to integrate Zigbee devices without cloud.
Unfortunately there are problems with the installation of the Conbee 2 stick.
I have installed the Add On deCONZ.
This I can call and under configuration I have:
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426596-if00
set, nothing else changed.
It is also visible in the sidebar.
When I open the user interface I can choose between Phoscon and deConz.
I click on Phoscon, don’t create a group and go to the 3 bars on the top left. After that on
Gateway. The first time I could update the firmware. Version 2.11.05
Next to firmware it says not connected! Is that correct?
Now I tried under Sensors to connect my Xiaomi Temp/Humidity Sensor WSDCGQ01LM
under Sensors.
This should work, right?
Unfortunately it was not found.
Also a motion detector from Lidl (Silvercrest) was not found.
Furthermore I tried to call deCONZ in the HA via Settings / Integrations.
I went to the button at the bottom right “+Add”, searched there for deCONZ
and called it. Here it asks for a HOST, the port 80 is default.
As host I tried everything possible, e.g. /dev/ttyACM0.
Then it always comes the message:
Connect to deCONZ
Unlock your deCONZ gateway to register it with Home Assistant.
Go to the deCONZ system settings
Press the “Unlock Gateway” button
SEND
I have clicked in Phoscon before under Gateway/Advanced on “Connect App”.
Unfortunately I always get the message
“No API key could be retrieved”.
Maybe someone can help me, what did I not pay attention to?
By the way, I have on my SD card in the Config.txt still the two lines:
enable_uart=1
dtoverlay=pi3-miniuart-bt
added.
Thanks a lot
with kind regards Jürgen
Translated with www.DeepL.com/Translator (free version)
Welcome to the forum.
This forum uses the English language to enable effective moderation and to be inclusive of the majority of users.
Please edit and translate your post to English. On-line translators are acceptable if you do not speak English.
Willkommen im Forum.
Dieses Forum verwendet die englische Sprache, um eine effektive Moderation zu ermöglichen und die Mehrheit der Benutzer einzubeziehen.
Bitte bearbeiten und übersetzen Sie Ihren Beitrag ins Englische. Online-Übersetzer sind akzeptabel, wenn Sie kein Englisch sprechen.
ok, sorry,
I have translated the text…
greetings…
